Oil pressure problem YM2210D
/ Oil pressure problem YM2210D #1
Pird
I have a YM2210D oil pressure problem. The oil pressure lite comes on AFTER the tractor warms up and the RPM is below 1500 psi. (outside temp is above 50.)
Above 1500-1600 rpm the lite stays off. I have had the tractor about a week and the man who serviced the tractor before delivery said he serviced it with 15 W 40. The oil level is normal. Along with troubleshooting suggestions, please comment on where I could best procure a pressure gauge (to test real pressure and maybe mount later) and a sensor, should that be the problem. Thanks
/forums/images/graemlins/cool.gif
/ Oil pressure problem YM2210D #2
First I would replace the oil sensor switch (pressure) switch and see what happens. They are cheap to buy.
Ernie
www.ernies.net
/ Oil pressure problem YM2210D #3
In my experience the sending unit works or does not work. The rpm related issue would tend to make me think oil pump, but I am NOT a mechanic....I pay people who are.
If I'm not mistaken, this was one of the "reconditioned" units, wasn't it? As I recall the original thread emphasized caution about recons (I know I said the midwest rebuilder line sounded bogus) and about the servicing dealer. Did you get any customer references per our suggestions? I am just curious. I certainly hope you can get this fixed, but with an almost immediate problem that apparently your seller is not going to stand behind I am wondering if you took any of the advice you asked for.
Original thread
http://www.tractorbynet.com/forums/showflat.php?Cat=0&Board=yanmar&Number=563208
/ Oil pressure problem YM2210D #4
Congrats on being a 2210 owner! This seems like something your dealer should have noticed and fixed prior to offering for sale. I think u are on the right track. Start with the connections, sender, check pressure and then look at the oil pump. I'd have to be there to be more help. Let your dealer know you have a problem he should help. lol
Thanks for the prompt replies.
The tractor was refurbished by a reputable firm. I checked its Internet site and confirmed with the owner on the phone.
I am also not a mechanic but don't want to pay one to fix a simple problem if that is what I have. I was under the impression that common parts like sensors and pressure gauges were commonly interchanged with parts available at many retail parts outlets. I was hoping someone could respond as to where/if I might get these parts, if in your opinion that is where I need to start, and be as specific as possible considering the information I have presented or query me for more info.
I really do appreciate the information but don't need the chastisement.
/ Oil pressure problem YM2210D #6
Sounds like the oil pressure sender to me. I have never had a problem on my Yanmar, but low/no oil pressure on several cars has always been a bad sending unit, available from any Yanmar parts dealer.
/ Oil pressure problem YM2210D #7
The sending unit is too cheap to overlook. Definitely try one before proceeding.
Bruce
/ Oil pressure problem YM2210D #8
</font><font color="blue" class="small">( The tractor was refurbished by a reputable firm. ... as specific as possible...)</font>
Order an oil pressure sender unit from the rebuilder as the first step. Pay by M/C if you have to. Tell him you want it shipped today.
If this request indicates he doesn't really stock parts then go to AutoZone, Kragen, NAPA etc and get a small pressure gauge and universal adapter kit. Mount it in place of the present sender. This is extremely simple. The entire project should cost under $25 and will give you the info you need, to decide to keep or return the reconditioned tractor.
I prefer a mechanical gauge with a 180 degree dial since most electronic gauges have a crowded scale and a few are really an on/off sender rather than proportional to pressure. This doesn't have to be a permanently mounted install, just a one time diagnostic tool so you know what to do next.
/ Oil pressure problem YM2210D #9
Pird,
I agree with LMTC on the pressure sender. They work or they are inoperative. Yours seems to be working, so that leaves a few possibilities:
Incorrect Oil, or viscosity of oil is too lite.
Oil saturation from fuel contamination.
Week oil pump...not very likely on Yanmar engines.
Excessive bearing ware.
A simple test is to see if you can ignite oil (away from any combustibles) with a match or cigarette lighter. If oil ignites rather quickly it is fuel contaminated. If it is very difficult or impossible to ignite than you have eliminated that whole problem.
As good as your dealer is, I think I would be asking him questions and make him aware of your problem no matter how insignificant (or catastrophic) so he is prepaired to help diagnose and repair.
Good luck, Mark
/ Oil pressure problem YM2210D #10
I have replaced hundreds of bad sending units that have acted the same way. Spend the $7 and see what happens.
Bruce
/ Oil pressure problem YM2210D #11
Pird,
Whatever the outcome is, I hope it's a cheap fix and a good tractor.
Regards, Mark
/ Oil pressure problem YM2210D #12
I'd do the following. If one doesn't fix it , go on to the next one
1. Replace the sender since it is cheap.
2. Check the clearance of the rod bearings with plasti gauge to see if they are with in specs.
3.If out of spec, replace rod & main bearings.
4.Change the oil pump
As to trying to ignite the fuel to check for contamination. That will work with gas , but diesel doesn't ignite that easy.
I can supply you with new or used OEM Yanmar parts.
/ Oil pressure problem YM2210D #13
I hope u did not take offense to what I said. If I remember correctly your tractor came with a parts warranty. I was suggesting that you get your tractor seller to fix the prob.. You Paid for a tractor without such problems. He should fix it for you. Best parts source is the dealers on this forum or other internet suppliers. Parts cross reference charts really are not available. These guys often know of parts that will work but your better off with a yanmar replacement. If you order one you'll get it in a few days. You could prob go to a JD dealer and ask for a sender for JD 950. It would prob be the right one but I don't know that for sure. I have a reconditioned 2210 also. I am very happy with it so far.....I bought a cd with several manuals on it ... ebay...
/ Oil pressure problem YM2210D #14
I tend to agree with others than oil senders tend to fail either permanently open.. or permanently closed.. however I'd slap a 9$ cheapy sunpro gauge on it to see what the pressure was really doing. I think sunpro sells a metric adapter kit with lotts of doodads and connectors for another 5$. If it turns out to have good pressure.. I'd rig up a 'T' and get a new sender, and run the sender and gauge in tandem.
I must say.. I'm not a fan of idiot lights.. Without a gauge, you miss lots valuable info abnout engine condition as it ages.
For instance.. with a gauge.. you can see a gradual decrease in pressure that might happen over a period of years thru normal wear.. a gauge would let you see this 'normal' drop. With a lamp.. you would not notice a 'drop', untill one day when the lamp comes on when it is beloew the senders threshold. Hard to tell if this was a 'normal' drop.. or a quick drop.. which deffinately signals a bad problem.. like sheared keyway in an oil pump.. etc. A lamp also won't distinguish between a few psi.. like 5 psi.. and 0 psi.. A gauge will.
Soundguy
/ Oil pressure problem YM2210D #15
Have you, by any chance, seen if the sender is leaking oil? A lot of the bad ones I have seen show low pressure because they begin leaking oil after pressure builds up.
/ Oil pressure problem YM2210D #16
I have not worked on this model, But I would buy a mechanical gauge and watch the oil pressure at different RPM's and compare it to the warning light and specs. Many engines can vary their oil pressure depending on the rpm. Some engines like Detriot Diesel 6-71 or 8-71 idle with around 5psi sometimes even less but run with 30 to 60 psi. This quite normal. Do you hear any unusal noise from the engine.Valve noise? Knocking from the lower end of the engine?Electrical gauges and senders can vary greatly. They are affected by voltage and their grounds. I would also check the simple fixes, Change the oil and filter with the known proper style filter (a quality filter, NAPA, WIX, Baldwin etc) and quality brand and weight of oil. Who knows what the unit was serviced with before you bought the tractor. Good luck. Let us know what you find.
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
John Deere 348 Square Baler (A65579)
John Deere 348...
New Landhonor 78" Rock Bucket  (A62679)
New Landhonor 78"...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
