Oil pan drain plugs?
/ Oil pan drain plugs? #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
I was just reading over on the Kubota forum of a tractor that had lost it's oil sump drain plug while in the field. Engine troubles followed.
There seems to be quite a difference of opinion on how drain plugs are to be installed. Some are saying you MUST use a torque wrench on the Aluminum pans.
Is there some change in methods where sealing /compression washers are no longer used, and the torque setting is making the seal?
I've never heard of it. Can you check your operator's manuals and see what is advised ? I'm sure any change must be in the past few years . I wouldn't expect anything new or novel before 2010. But Hey, What do I know?
36 views and no one has an operator's manual? ;-)
/ Oil pan drain plugs? #3
Most drain plugs use copper or aluminium washers (actually they're small metal gaskets). Less common is an o-ring in the plug. Either way the seal is made by the washer or o-ring. The torque ensures that the plug won't come loose, and that the washer is sufficiently compressed to effect a seal. The drain plugs with o-rings that I have seen are made so that the o-ring is compressed the appropriate amount when the bolt shoulder is hard against the pan.
Using a torque wrench is always a good idea, especially in an aluminium pan where it's easier to strip threads. Some people tend to over torque bolts, others tend to under torque them. Over torquers can strip threads. Under torquing can lead to plugs coming out.
All operators manuals list a torque value and expect you to use a torque wrench.
eric
Your generalized information is very clear. And using a torque wrench is a great method to match material requirements to assure a functional seal
Unfortunately, your last statement does not prove as a fact, as it pertains to sump drains. I have four tractors, Not one operator's manual states a torque spec for the sump drain plug. And the general torque values for fasteners of that size are grossly in excess of prudent.
Does the Branson literature specify a value?
Here is an interesting comment snagged off the web regarding "torque specifications" for sump drain plugs.
There isn't one, because it's not known if the drain plug is being removed/reinstalled with the engine hot or cold. Such as at a quick-lube place.
And because the threads in the oil pan are coated with oil, it has to be a wet torque spec.
So, the drain plug is tightened by feel.
[End quote]
Several important consideration there.
/ Oil pan drain plugs? #7
Been doing it "by feel" since the 70's with no issues.
Yes, me , from the late 60's ;-)
But there seems to be a movement afoot that would replace feel with a torque spec. Something I have yet to reconcile.
I was just looking for examples of operators manuals that describe replacing "feel" with blind and dumb numbers on a click wrench. ;-)
Are the advocates of the "scientific approach" missing some important aspects, like wet torque?
/ Oil pan drain plugs? #9
Yes. It is in the maintenance chapter but not the engine chapter with the other engine specs. I've seen that in other manuals.
In all the shop manuals I have the general section at the beginning that no one reads says to use a torque wrench. It's on page 4 in the Branson manual.
I've never seen a manual say to do it by feel. Even when there is no torque value for a fastener you're supposed to follow the general values.
I don't use a torque wrench for everything but it's there for anything critical. Sometimes I use it on oil drain plugs, sometimes I don't. I understand that while the manufacturer gives a single number the actual practical range is often fairly wide- tight enough to stay in and to compress the metal washer, not so tight as to strip the threads. If it's in an aluminium or magnesium block (not the pan that can be replaced) I use a torque wrench for sure.
I did once do an experiment to check my personal torque calibration on a range of fasteners by tightening them to what felt like the target torque and then checking with a torque wrench. Turns out I'm in the ballpark on small fasteners and too light on larger ones. Figures since I don't have a lot of upper body mass. I've worked on motorcycles previously owned by big brawny guys where every small fastener was tightened to where it was just starting to strip the threads.
/ Oil pan drain plugs? #10
I've worked on motorcycles, ATV's, chainsaws, jet skis, snowmobiles, and lawn equipment at dealers and have had to repair threads in aluminum. Back in the day, most people worked on their own equipment and stripped threads, now, most work is done at a shop and thread repair is not as common.
/ Oil pan drain plugs? #11
Checking a few of the pdf manuals I have on hand - FIL's Cub 7260 Service Manual shows torque values for the trans drain plug, but nothing for the oil pan. The Owners's Manual DOES have a torque spec for the oil pan plug.
I only have hard copies for the Kubota. Will check in a few.
Update: Y'all are exactly right for Kubota. Neither the Owner's nor the Workshop manuals list any torque spec for the drain plugs anywhere. Just "reinstall the drain plug". About the only thing the Owner's has is rear wheel bolt torque. Lotsa specs for most everything in the Workshop, but not those plugs. I did notice that the "general" fastener torque specs have different values for not only bolt material/grade, but also for what it threads into, either "Ordinariness" (;-) or "Aluminum". 9T bolts are only used for "ordinariness".
/ Oil pan drain plugs? #12
I have done that also. I think it is an excellent way for the beginner mechanic to learn how to "feel" varying torque ranges. And a refresher for the old pros that haven't turned many wrenches for years.
It sure would be easier to learn this if the manuals would give a little better guidance.
/ Oil pan drain plugs? #13
Some of my equipment advises to replace the copper washer every time you take of the drain plug.
None specify torque.
But I vastly prefer the Fumoto.
/ Oil pan drain plugs? #14
Just because there is no torque spec in the manual that you have for your tractor does not mean that there is no torque spec! Obviously, a steel plug in an iron oil pan is different from one in an aluminum pan, etc. The numbers are out there. But, as I've both prepared racing cars and motorcycles, and owned a light plane, there is one other way to be certain that critical items do not come loose (and in most cases, a drain plug is more critical than an engine mount bolt—at least on a tractor!) Safety wire! The wire and pliers are cheap, and a decent cobalt drill can set up up with holes in your bolt or nut head (I had a little "vee" fixture with a couple of different sized holes for drilling them across the apex of the hex.) Works great. Looks cool. And safety wire pliers are a lot of fun to spin.
