CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 9,406
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
I was just reading over on the Kubota forum of a tractor that had lost it's oil sump drain plug while in the field. Engine troubles followed.
There seems to be quite a difference of opinion on how drain plugs are to be installed. Some are saying you MUST use a torque wrench on the Aluminum pans.
Is there some change in methods where sealing /compression washers are no longer used, and the torque setting is making the seal?
I've never heard of it. Can you check your operator's manuals and see what is advised ? I'm sure any change must be in the past few years . I wouldn't expect anything new or novel before 2010. But Hey, What do I know?
