oil leak
/ oil leak #1
pmmully
Brevard County, FL
2006 Kubota L48 TLB
Hi all, I got a small oil leak from the bottom of my drivetrain. It is up by the clutch area. I am still learning this machine so I do not know exactly what piece this is. It may be upstream of this component. What is this component in the picture? It has oil on it when I wiggle the "stick", but it may be coming upstream.
It had no leaks that I could see prior to me getting it stuck in some soft material recently. the "stick" looks bent. Ideas?
Thanks in advance! Otherwise just an awesome machine!
/ oil leak
Apparently that is the clutch split pin plug. So, it appears I have a very small oil leak somewhere on a shaft seal, or elsewhere. It has actually basically stopped almost, and no leaks under pressure. I assume this means it is a dry clutch setup? It is clear, so it is hydro fluid, stick shows full.
I have also used the 4WD a lot, seen other posts where they talk about this.
/ oil leak #3
Don't see any pictures...
/ oil leak #4
Not sure on a L48 but when that happened on my L5740, it was a seal on the output shaft from transmission to the front wheels. Had it replaced when the drips changed to streaming when hot.
/ oil leak
here is the pic
/ oil leak
@MHarryE what was the overall process for that? What was the shop bill, or did you do it yourself?
/ oil leak #7
about 2000$ dollars. have to split the tractor to get to it. and splitting an l48 is probably more complicated. might be cheaper if you send the tractor in without the backhoe and loader.
/ oil leak #8
I could have done it but needed tractor immediately. Dealer couldn’t get to it for over a week - 2 tractors with same problem ahead of mine - so I traded.
/ oil leak #9
Dry clutch or hydraulic shuttle (no clutch) makes no difference at all, t's there to drain the bellhousing of acumulated water and leaking seals too.
When the drip goes to a stream, time for a split and a new seal. Have a drip on my M9 open station, I ignore it. Heck the gearbox holds almost 15 gallons so it would have to leak a lot to lower the fluid level.
/ oil leak #10
The more stripped the unit is when it's split, the less it costs because you get charged shop time to remove the FEL and backhoe which have to be removed to split it anyway.
/ oil leak #11
Here's what the surgery looks like just before the new parts get installed. I think parts were about $100, fluid was about $300 and the rest is lots of labor. You can see a hole where a shaft has been removed in the bottom of the open round casing. That's where the notorious seal is that often leaks.
/ oil leak #13
My goodness that’s not an easy job.
You are right!! That's what they mean when they say they have to "split" the tractor. Lucky that in this case, the split allowed the cab to stay on.
/ oil leak
So when you split it, what else should be done? Clutch, throw-out bearing, etc? In a boat when you pull the tranny, you usually do the damper plate cause of the PITA to do it again!
/ oil leak #15
You're probably going to get a lot of opinions on this one . . .
In my case, they didn't recommend doing anything else. They said the known failure point was indeed what was leaking and they really don't experience other failures right here. They replaced a suction tube that was observed to be split but that was external. Otherwise just installed the upgrade parts to resolve the FWD shaft seal leak.
/ oil leak #16
Big difference compared to replacing the clutch in a Ford 850 back in the day. Don’t know if I could or would try to split modern tractor. Major mechanical skills required. Certainly worth $175/hr shop time if you can do the work.
Had Kubota spilt a tractor to repair. Nightmare getting dealer to fix problems from the split. They had to re-split to restore fwd selector. Doing it yourself least you know it is done right.
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
FRONT MOUNT BLADE W/ MOUNTS (A63291)
FRONT MOUNT BLADE...
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
2025 Hydraulic Brush Cutter Skid Steer Attachment (A61572)
2025 Hydraulic...
