Oil Filters
/ Oil Filters #11
Most of the Filters are similar in filtering ability. There are several qualities of filter out there. Off-brand (such as Mobil that are used at the oil change places), name brand such as Fram, Wix, Purolaor, etc., and premium filtures made by the brand name purveyors (pure one and others). As long as the oil is relatively clean and changed reularly, it probably makes little difference which you use. On the other hand, if you change the filter and oil only once a season or twice and use the machine heavily or in dusty contitions, then it might make a difference. Probably how long an engine lasts depends on structural concerns such as how the metals are made, how regularly it is used, maintenance comes in third if it is done reularly, or first if not. Finally the quality of the fuel probably makes a difference.
With millions of auto engines made, it is not surprising to see some that last nearly forever with rebular maintenance and some that even with regular maintenance last 60-80,000 miles. There will be a statistical spread.
Maintenance works only if you do it. Long lay ups are bad for equipment. This can be minimized with proper pre-lay up procedures.
/ Oil Filters #13
<A target="_blank" HREF=http://groups.yahoo.com/group/yanmartractorownersgroup/message/5700>http://groups.yahoo.com/group/yanmartractorownersgroup/message/5700</A> This URL plus the replies should be what you need. If it works you owe me 5 minutes of search time.
/ Oil Filters #14
All of theese will work just fine. Napa 1064,1344,1334, Fram ph3593a,ph6811, Carquest 85334,b4459, AC pf1127, Motorcraft fl810, STP s2808, Wal-Mart SuperTech st2808
/ Oil Filters #15
Norm,
Thank you for the search you did on my behalf. It does work and gives me the info I have been looking for.
I was not familiar with the Yahoo groups site so had not been there. I did spend much much more than five minutes on my own search with no success.
I apologize if I sounded like I was whining./w3tcompact/icons/blush.gif /w3tcompact/icons/tongue.gif /w3tcompact/icons/grin.gif
Gary
/ Oil Filters #18
Dennis
I've worked at several factories one of which manufactured OEM water pumps. The sister factory to this is nearby and manufactures filters. At the pump factory alot of change-overs consist of changing the box. The pump is the same and shipped to major suppliers with their labels. I've not personally worked at the filter factory (yet) but I know several that do. I'm sure the same applies. We also have a large manufacturer of stain that I've worked at years ago. 2 yes 2 stains on the shelf with different names of colors are the same stain. Changeover consists of changing the label on the cans. All this means is that some of the names of product mentioned above I know come from the same (real) manufacturer. Some parts are/maybe changed but the quality is the same. I only worry about some products made outside the US. I have worked overseas too.
/ Oil Filters #19
Napa and Carquest oil filters are made by Wix. The STP and the Wal-Mart SuperTech filters appear to be the same. Both have Champion Labratories, Inc. on the box and are made in the US.
/ Oil Filters #20
Gary,
If you don't have a parts manual for the YM1610, I would highly recommend you get one. I have parts manuals for YM1110, YM1301, YM1510, YM1702, F13, F14, and F15. All list the oil filter with a Yanmar part number. If you have that part number, you can go to the <A target="_blank" HREF=http://www.wixfilters.com/filterlookup/>Wix oil filter web site</A> and do a cross reference. By the way, all of the above tractors use the same Yanmar part number for the filter: 124450-35100. This crosses to a couple of Wix filters including the 51064 and 51568 (Napa 1064 and 1568).
STORAGE FEES (A59908)
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
John Deere 5055E (A53317)
John Deere 5055E...
