Oil filter wrench
   / Oil filter wrench #41
Maybe I’m doing something wrong.
This is after the initial filter change.
I’ve always hand turned the filter until it’s snug, then mark the edge, and turn another 50% (1/2 turn).
When it’s time to replace the filter, it’s really easy to get off. I don’t need much of a turn with a strap wrench and the rest can be unscrewed with a hand.
I’ve never lost any oil. The filters are always snug and don’t move by hand - but once the strap wrench loosens it a tad it screws off easily.
Have I just been lucky or is my process ok?
MoKelly
Same here. Even though I do mark the filter, I just go by eye.
Never had any leaks or filter coming loose and I take them off by hand just as easy.
I don't think I even have a filter wrench around.
   / Oil filter wrench #42
I agree that there is not one tool that will work in all cases. I have strap wrenches, chain wrenches, multiple sizes of end cap wrenches, fancy ratchet powered clamp on end wrenches. I have still had to resort to the screw driver driven through the filter approach at times. The one on my Triumph motorcycle is the worst. It is a half sized filter in a recessed hole to where only the end is exposed. What a pain. K&N started making a filter for that bike that has a large hex nut pattern stamped into the end of the filter so you can use a 15/16" box end wrench to remove.
Someone made the comment that people put them on too tight. So true. But it also seems they tighten themselves. I have had filters that I have put on myself just hand tight that require major torque to loosen. One trick I have learned is that sometimes they seem to be less tight if you let the engine cool completely,
i had to do just the opposite. my rtv had 400 hours on it when bought it and had never been serviced. i got all but 1 filter off, don't remember which one wouldn't come off..
i decided to run it up to temp and try again. it worked but the kubota filters in general have been the hardest for me to remove, tractor and rtv.
   / Oil filter wrench #43
I tighten engine oil filter by hand as tight as I can. Had a filter come loose once following their directions. For the hydraulic filter, you have to use a wrench to snug it up.
Use the 2 finger wrench on every filter. Never had a problem.
   / Oil filter wrench #44
I don’t know if this works on every filter, but on my car and pickup, as tight as I can get it with one hand, and usually can loosen it with two hands. Never a leak, so far, but only been doing this for 25 years or so.
On my MF 1754, I do give the hydraulic/HST filter a little more than that with a wrench, but less than 1/4 turn.
   / Oil filter wrench #45
Filter story.
Certain models of Jeeps of a vintage has serious filter problems.
An engine option had the filter located just too close to suspension components.
The result was a dent in pressure relief valve area and when a cold day pressure would build to the point that the filter simply blew off the engine.
My BIL had that version and it took a bunch of sleuthing B4 they discovered the cause.
(It was a V8 installation)
   / Oil filter wrench #46
I don't know how far I go once it is snug. I tighten then filter as tight as I can get it with one hand, still need a wrench to get them off. I've never had a problem with oil leaks.
   / Oil filter wrench #47
Can any one tell me a trick to get the oil filter off my 1726E? It's tucked down among other stuff so it's very hard to get a wrench on (See attached photo) (and it seems to be on very tight). I've tried several wrenches but none are able to get a good enough grip on it and allow me to exert the force needed.
Yup, I recognize that problem. One of those three fingered types, shown in a picture below, will amaze you and solve your problem.
   / Oil filter wrench #48
For the biggest hydraulic filter on my LS XR4155 I wound up buying this wrench at Fleet Farm and very thankful I bought it because it was pretty difficult to get loose, had to use a extendable ratchet to get it loose, I’m very confident that a screwdriver wouldn’t have worked. The wrench was about $14. Supposedly has lifetime warranty.
   / Oil filter wrench #49
Hey big barn looks like you have a good selection of filter wrenches but I think you forgot one the (screwdriver) 😁
   / Oil filter wrench #50
What is really so sad is at one time WIX filters had a hex plate on bottom you could put a wrench on.... It went away with to concept of saving money, but it gave birth of to the "filter wrench market".....
BUT K&N seems to have the concept, and IF you can find K&N filter the fits your needs....
2019 Ford Explorer (A55788)
2019 Ford Explorer...
Sterling AT (A55302)
2022 New Holland Workmaster 255 (A54865)
2022 New Holland...
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
2022 BOBCAT T76 PLATINUM R-SERIES SKID STEER (A52706)
2022 BOBCAT T76...
11 10 FOOT BY 5 FOOT LIVESTOCK PANELS (A53843)
11 10 FOOT BY 5...
