Oil filter wrench
   / Oil filter wrench #21
You only need one..the one that works.
   / Oil filter wrench #22
Kubota has a really bad habit of installing their filters and then painting the chassis. Makes for a really hard to remove filter first time around. ....
I figure the guy/gal on the assembly line grabs a filter from a bin and screws it on. No oil on the rubber seal, no oil dripping on the flange. Then the engine oil is added. After a time, with engine heat, the rubber bonds to the bare metal. Like an egg to an unseasoned fry pan.
Stuck like Chuck...
   / Oil filter wrench #23
Not enough room on the tractor engine for this type.
Ralph ... From the OP's photo, I would use a ratchet, extension bars and a flex joint. I don't see a lack of space. There is at least 90 degrees of movement available.
   / Oil filter wrench #24
I remember years ago, 1978 or 1979, when we got a brand new Dodge truck at work and when it was time to change the oil filter on the 318 cu engine, I used a regular filter wrench on it which simply collapsed the filer. Then I tried to drive a screw drive through it to spin it off. That just ripped the filter apart totally. I ended up removing all of the filter housing and guts until I was down to the steel end that screws onto the stub. Then I used a punch in the holes the oil flows through and hammered it off, and it took some serious hammering to get it to break free. We didn't have a hoist so the truck was up on jack stands and I was laying on my back to do all this.
   / Oil filter wrench #25
that's how i finally got my brothers filter off, sam deal, no hoist, basically beat it to death
   / Oil filter wrench #26
The filter wrench that is form fitted to the end of the filter, (the cap style), is the easiest, most convenient way to remove them. especially in a tight spot. It must fit precisely, to work. But, when they do they work great.
There are about 20 different ones now, and the only way to know for sure is to take a brand new filter out of the box in the store, and find a wrench that fits it. some fit better than others, so try any that seem to be the right size.
I have most of them now, so I usually have one that fits.
When this fails, I move to the more aggressive crushing type wrenches.
   / Oil filter wrench #27
There's little space to the side for the rachet hole like this one has. The one I use (the 2 fingered one from NAPA) has the ratchet hole right in the center. Doesn't need clearance.
   / Oil filter wrench #28
I have quite a few oil filter wrenches but like using the ones shown in post 26. I did not have one for the filter on the Kawasaki Mule and tried channel locks. Started to crush the filter and backed off. Ordered the "socket" style for $10 from Amazon and had it in a couple of days. Had to beat it on a bit as I had damaged the filter with the channel locks but it worked.
Luckily, it was also the size I needed for the filter on my Generac and did the oil change on it the same day.
Using the right tool makes the job so much easier.
I had one filter that would not come off. It was on a Polaris Ranger 850. It had been previously serviced by the dealer and some gorilla had put it on. The Ranger had to go in for other work so I had the dealer get the filter off and warned them to do it right this time. No more issues.
   / Oil filter wrench #30
TRAILER MOUNTED WATER PUMP (A55745)
TRAILER MOUNTED...
2021 BOBCAT MT100 STAND ON SKID STEER (A52706)
2021 BOBCAT MT100...
WACKER NEUSON LIGHT TOWER (A55745)
WACKER NEUSON...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
