Oil filter wrench
/ Oil filter wrench #21
You only need one..the one that works.
/ Oil filter wrench #22
Kubota has a really bad habit of installing their filters and then painting the chassis. Makes for a really hard to remove filter first time around. ....
I figure the guy/gal on the assembly line grabs a filter from a bin and screws it on. No oil on the rubber seal, no oil dripping on the flange. Then the engine oil is added. After a time, with engine heat, the rubber bonds to the bare metal. Like an egg to an unseasoned fry pan.
Stuck like Chuck...
/ Oil filter wrench #23
Not enough room on the tractor engine for this type.
Ralph ... From the OP's photo, I would use a ratchet, extension bars and a flex joint. I don't see a lack of space. There is at least 90 degrees of movement available.
/ Oil filter wrench #24
I remember years ago, 1978 or 1979, when we got a brand new Dodge truck at work and when it was time to change the oil filter on the 318 cu engine, I used a regular filter wrench on it which simply collapsed the filer. Then I tried to drive a screw drive through it to spin it off. That just ripped the filter apart totally. I ended up removing all of the filter housing and guts until I was down to the steel end that screws onto the stub. Then I used a punch in the holes the oil flows through and hammered it off, and it took some serious hammering to get it to break free. We didn't have a hoist so the truck was up on jack stands and I was laying on my back to do all this.
/ Oil filter wrench #25
that's how i finally got my brothers filter off, sam deal, no hoist, basically beat it to death
/ Oil filter wrench #26
The filter wrench that is form fitted to the end of the filter, (the cap style), is the easiest, most convenient way to remove them. especially in a tight spot. It must fit precisely, to work. But, when they do they work great.
There are about 20 different ones now, and the only way to know for sure is to take a brand new filter out of the box in the store, and find a wrench that fits it. some fit better than others, so try any that seem to be the right size.
I have most of them now, so I usually have one that fits.
When this fails, I move to the more aggressive crushing type wrenches.
/ Oil filter wrench #27
There's little space to the side for the rachet hole like this one has. The one I use (the 2 fingered one from NAPA) has the ratchet hole right in the center. Doesn't need clearance.
/ Oil filter wrench #28
I have quite a few oil filter wrenches but like using the ones shown in post 26. I did not have one for the filter on the Kawasaki Mule and tried channel locks. Started to crush the filter and backed off. Ordered the "socket" style for $10 from Amazon and had it in a couple of days. Had to beat it on a bit as I had damaged the filter with the channel locks but it worked.
Luckily, it was also the size I needed for the filter on my Generac and did the oil change on it the same day.
Using the right tool makes the job so much easier.
I had one filter that would not come off. It was on a Polaris Ranger 850. It had been previously serviced by the dealer and some gorilla had put it on. The Ranger had to go in for other work so I had the dealer get the filter off and warned them to do it right this time. No more issues.
/ Oil filter wrench #30
/ Oil filter wrench #31
that would work (as I did use strap wrench before buying a grasp\claw type) on my gc2400 oil but not on the mf1532 I service. also hyd filters are a whole other subject. fwiw no strap wrench works on my 2010 mercury marquis LOL
/ Oil filter wrench #32
Hydraulic filters are another subject ... The large cans 6 -8 inch diameter are too much for most filter wrenches. The cans collapse BUT... Caterpillar sells a branded strap wrench that is very good. It doesn't collapse the can. Unbelievably, purchasing it at a Cat dealer (p/n 185-3630) is less expensive than elsewhere (Amazon).
Amazon.com: Caterpillar Filter Strap Wrench 185-3630: Automotive
/ Oil filter wrench #33
Interesting.....I bought the Gearwrench strap wrench but have not tried it yet. I'll keep the Caterpillar one in mind. THNKS
Amazon.com: GEARWRENCH 3/8" & 1/2" Drive Heavy-Duty Oil Filter Strap Wrench, 3529D: Home Improvement
/ Oil filter wrench #34
make sure you take the new filter with you to buy the wrench! i have a universal set that fits nothing i own. thank goodness i still have the 50 year old strap wrench!
/ Oil filter wrench #35
I agree that there is not one tool that will work in all cases. I have strap wrenches, chain wrenches, multiple sizes of end cap wrenches, fancy ratchet powered clamp on end wrenches. I have still had to resort to the screw driver driven through the filter approach at times. The one on my Triumph motorcycle is the worst. It is a half sized filter in a recessed hole to where only the end is exposed. What a pain. K&N started making a filter for that bike that has a large hex nut pattern stamped into the end of the filter so you can use a 15/16" box end wrench to remove.
Someone made the comment that people put them on too tight. So true. But it also seems they tighten themselves. I have had filters that I have put on myself just hand tight that require major torque to loosen. One trick I have learned is that sometimes they seem to be less tight if you let the engine cool completely,
/ Oil filter wrench #37
I feel your pain, my BMW is the same way
/ Oil filter wrench #38
My CUT filter is also very inaccessible.
My best working filter wrench is simply about 12 inches or so of old seat belt material and a pair of vice grips.
I wrap the belt, clamp the vise grips such that when I lever the strap tightens snugly and lever away.
My filter is so snuggly tucked in there that nothing else can clear it but that thin belt webbing.
Also I have a pair of HD rubberized gloves that I've dedicated to those messy jobs.
As I've mentioned elsewhere, I discovered a quick squirt of WD40 floats all that messy dirty oil off of my hands. Simple soap and water then leaves them 'finger eating clean'.
/ Oil filter wrench #39
Supposedly good for your joints as well...
/ Oil filter wrench #40
Maybe I’m doing something wrong.
This is after the initial filter change.
I’ve always hand turned the filter until it’s snug, then mark the edge, and turn another 50% (1/2 turn).
When it’s time to replace the filter, it’s really easy to get off. I don’t need much of a turn with a strap wrench and the rest can be unscrewed with a hand.
I’ve never lost any oil. The filters are always snug and don’t move by hand - but once the strap wrench loosens it a tad it screws off easily.
Have I just been lucky or is my process ok?
MoKelly
