Oil Filter Comparison
/ Oil Filter Comparison #61
Yea we still are dealing with that double post issue? I have done it a few times myself i see recently?? What happended to the outcome of that Dbl post thread we had like a year ago going and Muhhamad was "looking " into it?
I've had to delete at least three double posts in the last week. The common theme when it seems to lose its mind is when a popup asks me if I really want to leave that page? I am sure not an IT guy, but I do know that message
hasn't come up in normal use.
/ Oil Filter Comparison #62
yep.. I see it often
/ Oil Filter Comparison #63
they have been holding up for me on a tractor.. 1 year anyway. though no oil gets on them.
a lil gas sometimes from over choke though.
they are cheap enough to chage out more often if they do get damaged though.. :)
I ran them for 50k miles or more on the ranger in my avatar that I still own with 290k miles on it. Before that was years of super tech I think? anyway I now run purorlator or wix or motorcraft. But I think it was that truck but seems like they coating would wear off, and I use to change them monthly back when I commuted! Or maybe its on the old K10, yea I think that's the one as it sits verticle and that thing leaks at every gasket and stays wet. and it gets yearly changes on it.
/ Oil Filter Comparison #64
you don't always get that popup I don't think? But I do see it, I thought they were working on that like I said a YEAR ago!
/ Oil Filter Comparison #65
i have a couple rowcrop forsds that will take the fl1a or fram ph8a .. but I use the supertech on them as it is shorter and makes fighting with the frame rail easier.. :)
/ Oil Filter Comparison #66
A few years ago I was invited to tour the Baldwin filter factory . The engineering dept. had their filters and other brands there , cut a part checking the micron of paper media , on machines pressure testing , etc. The one test I was impressed with was pouring shavings in a circulation line , circulating , then checking the fluid for how much didn't get filtered . They pointed out , no filter can be 100% efficient or the fluid or air would not flow . It takes a lot of $ , testing and expertise to know what is in a filter .
/ Oil Filter Comparison #67
There is not much for them to cheap out on a cartridge filter.
What baffles me is just why the cartridge filters I buy for my '04 Saturn L-300 are so d*** expensive, even if they are a Fram brand. Tiny little paper and plastic elements cost as much as a large Mobil 1 premium spin-on filter for my GMC. BTW, I am currently using WIX brand filter elements for that car as they seem to be better made than any other brand. I also use the Wix spin-ons for my Deere.
/ Oil Filter Comparison #68
because it is for a saturn L.
go to napa nd buy a set of points for a ford 8n.
now go buy a set of points for an old muscle car that uses a equivalent ( crossover ) set.
the tractor points are cheaper. :)
/ Oil Filter Comparison #69
And your "point" is....????
/ Oil Filter Comparison #70
I'm just guessing here but was your Saturn based on the German Opel? Could it have an unusual spec filter?
2023 Ford F-150 Crew Cab Pickup Truck (A59230)
2023 Ford F-150...
Compressor (A55973)
Compressor (A55973)
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
Deere 335P (A53317)
Deere 335P (A53317)
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR4AJ276527 (A61165)
2010 International...
