Oil & Fuel Oil Drain plug ? 5083E
/ Oil Drain plug ? 5083E #1
wideurt
Time to change the oil. The drain plug takes a square male socket. 3/8 driver is to small. Does anyone know what size this is Thanks
/ Oil Drain plug ? 5083E #3
Have you tried a 1/2" drive?
/ Oil Drain plug ? 5083E #4
Went to JDparts catalog and the plug part number is R515195. Went to part detail looked up the part and the following specs where provided.
I second WilliamBos post indicating 10mm
English Metric Specification
Weight 0.09 LBS 0.04 Kg
Thread Diameter 22.000 MM
Thread Pitch 1.500 UNITY
Drive Size 10.000 MM
Length 10.000 MM
Length 13.000 MM
Diameter 30.000 MM
Drive Type SQSCH
/ Oil Drain plug ? 5083E #5
A 1/2" square drive works on my JD 5225 engine-oil drain plug.
2011 FREIGHTLINER CASCADIA (INOPERABLE) (A67714)
2011 FREIGHTLINER...
PORTA POTTY (A67714)
Turf Tiger Velocity Plus (A64557)
Turf Tiger...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
2014 Fiat 500L Hatchback (A66738)
2014 Fiat 500L...
2005 FREIGHTLINER FLAT TOP DAY CAB ROAD TRACTOR (A65054)
2005 FREIGHTLINER...
