Oil & Fuel Oil Drain plug ? 5083E
/ Oil Drain plug ? 5083E #1
wideurt
Time to change the oil. The drain plug takes a square male socket. 3/8 driver is to small. Does anyone know what size this is Thanks
/ Oil Drain plug ? 5083E #3
Have you tried a 1/2" drive?
/ Oil Drain plug ? 5083E #4
Went to JDparts catalog and the plug part number is R515195. Went to part detail looked up the part and the following specs where provided.
I second WilliamBos post indicating 10mm
English Metric Specification
Weight 0.09 LBS 0.04 Kg
Thread Diameter 22.000 MM
Thread Pitch 1.500 UNITY
Drive Size 10.000 MM
Length 10.000 MM
Length 13.000 MM
Diameter 30.000 MM
Drive Type SQSCH
/ Oil Drain plug ? 5083E #5
A 1/2" square drive works on my JD 5225 engine-oil drain plug.
2002 PETERBILT 330 VACUUM BOBTAIL (A67714)
2002 PETERBILT 330...
2009 CHEVROLET IMPALA 4 DOOR CAR (A66091)
2009 CHEVROLET...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2009 FORD CROWN VICTORIA (A66091)
2009 FORD CROWN...
2016 CATERPILLAR 305E2 CR EXCAVATOR (A65056)
2016 CATERPILLAR...
2015 Ford F-550 4x4 Mason Dump Truck (A66736)
2015 Ford F-550...
