oil cooler
/ oil cooler #21
Josh, where did you measure those temps at, the tank, cooler, or just where. I have never checked mine, will see what it is.
After mower grass on a 85 degree day for about half an hour (engine at full throttle) the Shell Rottella 15w-40 was 147 degrees.
/ oil cooler
Dragging harrow for 30ish minutes. 190 reservoir oil 170 tank metal. At this point i couldnt go up the smallest incline. Just for a test i hooked up pto to log splitter and my oil cooler fan came on instantly.
Should i plumb the oil cooler into the main hydraulics rather than just pto? Running 10w40 like the book says. Kansas summer. Temp is 90-95 and humid. Running engine at full or 3/4 makes no difference. 30hp deutz. It never bogs, i just hear hydraulic whine. Any ideas? Basically i have no power after machine gets worked for a good 30min (if you haven't read the whole trend)
/ oil cooler
Talked to tazedale. They said my pump is shot. They want me to send it in for rebuild.
/ oil cooler
Talked to tazedale. They said my pump is shot. They want me to send it in for rebuild. $1500
/ oil cooler
/ oil cooler #29
Wow. You're lucky to have the exact model number of the pump. You might want to call B&P on Monday (they're in Ashland VA I think) and enquire about sourcing a new one. Wouldn't hurt to know the cost. Although, it may take quite a while to get one.
/ oil cooler #30
I'm surprised they left that tag on there. That information is worth gold to many owners.
/ oil cooler #31
This is the same pump the 425 uses, in a smaller displacement. In the 1430, the displacement is 28 cc. The 425 uses the 21 cc version (M4PV21-21). I suspect the other numbers are the same as well since they refer to the mounting format, SAE fittings and such.
If I were betting, I'd bet this isn't the original pump on the tractor. It's probably the original model, just not the original pump.
/ oil cooler #33
5dphilip,
What did you decide? Did you try to find a replacement pump?
/ oil cooler
After i finished sulking, i called terry. He confirmed i had the correct pump. I called B&P and they gave me a dealer in missouri (closest to me). The missouri shop seems to think they can rebuild it for 200-300. They also sent me a parts diagram to see if i wanted to do it myself. I wanted to finish some things before i put the tractor down. So I'm trying to stretch it until September. Regardless everyone feels that if you lose power when the machine gets warm and your engine doesn't bogg down, it is the pump.
/ oil cooler
Does anyone have experience rebuilding Bondioli and Pavesi pumps? I cannot find any "how to" videos or literature. The dealer in Missouri sent me a parts breakdown and told me if I felt comfortable doing it, I could rebuild it myself and they'd send me the parts. The dealer said one special tool is needed to keep "something" in place.
/ oil cooler #36
B&P pumps are VERY rare in the US. I doubt you'll find anything. Also, if rebuilding yourself, you can't allow ANY contamination or you're asking for future problems.
You can buy the pump brand new for about 20% more than the rebuild cost at PT. However, it's a four month wait because it has to come from Italy. With PT, you get a very fast turn around. All depends on your priorities and price sensitivities.
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2014 Chevrolet Equinox SUV (A64557)
2014 Chevrolet...
Small Indian Statue (A64557)
Small Indian...
2015 Global Environmental Street Sweeper (A64553)
2015 Global...
1143 (A63745)
1143 (A63745)
