Oil & Fuel Oil capacity 2130 different
/ Oil capacity 2130 different #1
Ausmac
Proserpine QLD
Massey Ferguson 188, JD 2130, Fiat 650
Hi all. Just changed a lift pump out on the 2130 and dropped the oil as it had been taking on diesel. The book says 9 quarts oil capacity. Can anyone tell me why mine only took 6.5 quarts? I did not change the filter and verified the dipstick is correct AT21534 stamped on. Also verified the oil pressure warning light works and was not lit when running.
/ Oil capacity 2130 different #2
Maybe it has 2 oil drain plugs......:confused3:
Just went and had another look. Definitely one sump plug.
/ Oil capacity 2130 different #4
Generally the oil capacity is given for a completely empty engine - like new or freshly overhauled. That could account for some of the difference. Not replacing the oil filter could account for a bit more.
Thanks. I was wondering if the sump pan maybe had a lot of sludge on it displacing the oil and therefore taking less?
/ Oil capacity 2130 different #6
Trying to determine if there is sludge in the oil pan may be worthwhile, for peace of mind if nothing else.
The part drawing looks to be compartmentalized a bit, and I see that the pan gasket is still available.. part # R49515, if you went ahead and removed the oil pan.. sludge won't be helping the oil pump in that pan if very bad.
/ Oil capacity 2130 different #7
JD2520 RC utilizes same engine oil pan & dipstick & it lists engine oil cap @ 7qts
/ Oil capacity 2130 different #8
The oil filter will be some of the oil not accounted for. Does your tractor have an engine oil cooler? That could also account for some of the oil.
7 quarts Jim? Maybe I am wrong then. Checked a few sites yesterday and they all said 9 (or 8.5 litres). Zebra I have a section on the radiator which I thought was trans cooler? The sump pan is a simple drop off job right? New gasket and away I go?
/ Oil capacity 2130 different #10
JD parts shows an adapter at the oil filter for an oil cooler. I've never actually seen one. The cooler to right of the radiator is a transmission cooler.
I would not drop the oil pan. It is simple unbolt and new gasket.
/ Oil capacity 2130 different #11
Not drop it, but just change the gasket?
Sorry, figure of speech! As in drop it come of without doing anything other than draining the oil. Maybe I say lower the oil pan....
Ok maybe I do not remove it. I wonder where the missing 2 quarts of oil belong. Tractor is running fine and oil pressure light does not light up so I guess that is alright?
