Oil & Fuel Oil a bit high...
   / Oil a bit high... #1
Happyman
Kents Store, Virginia
Kubota Grand L 3940
I checked the oil in my L3940 before starting some work the other day and it was about an inch above the full mark. At my last oil change I filled the engine with the proper amount and seem to recall that it measured just fine on the dip stick. If it was this high I would have drained some out.
This is my first diesel and I'm not sure if too much oil can cause a problem. Should I drain some out or is it ok to leave it high?:confused:
I failed to check it after the engine was run (the tractor had been sitting unused for about 5 days when I checked the dip stick) and was wondering if after it ran the level would go back down due to the oil filling the system.
Advice please:eek:
   / Oil a bit high... #2
Take some back out till it is right on the mark. Then keep checking it every time you use it. It could be a leak in the anti freeze somewhere and getting in your oil. If it goes back up I would take it in right away and maybe get an oil sample to see if it is getting antifreeze.
   / Oil a bit high...
Thanks for the advice. I visited my local dealer today (buying a PHD, Landscape Rake and possibly a disc hoe :D ) and he too recommended I drain some out. He also asked if it smelled like fuel or was discolored. Going to my farm tomorrow so I'll check all this.
I hope it was just a brain fart on my part during my last oil change :eek: .
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
1998 6X12 Utility Trailer (A56859)
1998 6X12 Utility...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
30KW GENERATOR (A58214)
30KW GENERATOR...
2018 John Deere 470G Hydraulic Excavator (A56857)
2018 John Deere...
