Oil & Fuel Oil a bit high...
   / Oil a bit high... #1
Happyman
Kents Store, Virginia
Kubota Grand L 3940
I checked the oil in my L3940 before starting some work the other day and it was about an inch above the full mark. At my last oil change I filled the engine with the proper amount and seem to recall that it measured just fine on the dip stick. If it was this high I would have drained some out.
This is my first diesel and I'm not sure if too much oil can cause a problem. Should I drain some out or is it ok to leave it high?:confused:
I failed to check it after the engine was run (the tractor had been sitting unused for about 5 days when I checked the dip stick) and was wondering if after it ran the level would go back down due to the oil filling the system.
Advice please:eek:
   / Oil a bit high... #2
Take some back out till it is right on the mark. Then keep checking it every time you use it. It could be a leak in the anti freeze somewhere and getting in your oil. If it goes back up I would take it in right away and maybe get an oil sample to see if it is getting antifreeze.
   / Oil a bit high...
Thanks for the advice. I visited my local dealer today (buying a PHD, Landscape Rake and possibly a disc hoe :D ) and he too recommended I drain some out. He also asked if it smelled like fuel or was discolored. Going to my farm tomorrow so I'll check all this.
I hope it was just a brain fart on my part during my last oil change :eek: .
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
Toro Multi Pro 5800 (A55758)
Toro Multi Pro...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
More info coming soon! (A56859)
More info coming...
