offset bushhog
/ offset bushhog #1
dcomp
lewisburg, TN.
ford 540 B
I've always wanted to build something like this never knew they where already out there any ideas on how this one is driven or ideas on how to build a drive for a homemade one. Maybe chain and sprocket ?
/ offset bushhog #2
I appears to have 3 gearboxes, and a shaft that run along the boom.
/ offset bushhog #3
I am surprised they don't have any counterweight on it, at least that I can see.
/ offset bushhog
I wondered about that too it seems like it would really rack your lift arms.
/ offset bushhog #5
I know. Seeing how the far 3 pth arm has no down force to counter the torquing / twist effect, how do they stop this? Anchor to the drawbar?
/ offset bushhog #6
How big of a tractor u going to put it on????. i would design a way to put tractor suite case weighs on it so u can +/-any counter weighs
/ offset bushhog #7
I was just going to say... you need a heavier tractor to handle it... My 3011 has no problems lifting the 600kg, 2 meter Krone mower but in a heavy stand you keep correcting the steering because the offset pulls the nose into the uncut grass...
/ offset bushhog #8
We have an Alamo ditch bank mower at work. same principal only it is a dedicated mower. It has a hydraulic pump on the pto and works well. Like others have said though it has something in the line of a 50-60 gallon aux. hyd. tank as counter weight opposite the deck and it is very noticeable that it favors the deck side. I would suggest at least to match the weight of the deck if not go 20% to 25% higher for counter weight if you want good steering and traction. Also a good hefty tractor is helps to keep you going straight.
The mower this newer one replaced was shaft driven and was diverted through gearboxes at each 90* bend in the system. not nearly as flexible and lots of greasing required.
Good luck if you do decide to go about it and be safe.
PALLET OF PRESSURE WASHER FUEL TANKS (A68842)
PALLET OF PRESSURE...
AUCTION STARTS HERE @ 9AM (A65056)
AUCTION STARTS...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
86 (A63290)
86 (A63290)
2017 Ford Transit 250 Cargo Van (A66736)
2017 Ford Transit...
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
