Off grid solar system design help?
/ Off grid solar system design help?
Greatly appreciate the info. Well, the observations were correct, the panels were hail damaged. The search continues on.
I bought a 70v 15w controller, any suggestions on what I want to Target for panel watts? I figure that my angles will not be close to optimal and there might be some shading.
/ Off grid solar system design help? #22
Never heard of this odd thing: 70v 15w controller,
controllers come in 12, 24 and 48 volts and some
have 36 volts
willy
/ Off grid solar system design help? #23
We have a off grid cabin and I'd like to use a solar panel to power some low voltage lights. My thinking is to buy some 400 watt, 40 volt solar panels and use them to charge some semi truck batteries. I can get these batteries super cheap used. Because the batteries would not be matched, I was thinking there's be one solar panel and controller per battery. I'm guessing two setups would be enough to power the led lights. I only want to power lighting, any other power demands would be on the generator. Does anybody have experience with a system like this? I want to confirm my approach before buying any parts. These are the panels I was considering: Solar panels
i have precisely 3 setups pretty much as you describe. all my panels are recycled house 24v 250w panels.
all mine are 24v with 2 batteries in series and all 3 use cheap chinese pwm controllers ( all rated at 30A so i can have a common spare) . one is a pump controller for a 24v solar lift pump (2 x 7ah alarm batetries in series with 1 panel) , the other 2 are set up in shipping container (2 x 80ah sealed lead acids in series / 2 panels in paralell) and machinary shed (2 x z80 marine batteries / 2 panels in paralell) .
/ Off grid solar system design help? #24
Buying individual pieces without an overall plan? What can you connect to a 15w controller? Can you provide a link?
I just bought this cheapy https://www.amazon.com/gp/product/B07FT7RRGT/ref=ppx_yo_dt_b_asin_title_o03_s01?ie=UTF8&psc=1, but I already know what it connects to.
/ Off grid solar system design help? #26
The Victron site answers you pv question.
220watts @ 12 vdv
440watts @ 24 vdc
Note:
Safety
EN/IEC 62109-1, UL 1741, CSA C22.2
1a) If more PV power is connected, the controller will limit input power. 1b) The PV voltage must exceed Vbat + 5V for the controller to start.
Thereafter the minimum PV voltage is Vbat + 1V
2) A PV array with a higher short circuit current may damage the controller.
Thanks for pointing out the wattage. Theoretically a 250w panel would be more than sufficient. However, I know that my installation won't be optimal. The install angles will be wrong and it's likely there will be shading. What I was trying to ask is; how much do I need to oversize the panels to maximize the potential of the controller?
/ Off grid solar system design help? #28
if you would like some fairly exact numbers, maybe take a look at the NREL (National Renewable Energy Lab) online calculator program called PVWatts. The have a 30+ year database across the US and points beyond.
It uses your location, equipment type, install angles, direction, losses across inverters, etc., and gives you month-by-month estimates of production -- in practice, we find their model typically within 1%. Here is the link. You can change numbers, equipment, and mounting angles, directions, and see how that changes things. Or you can just use the model defaults. >> PVWatts
But for a shotgun number, if you take your total PV rated DC watts, with a typical US install, and go with 80% (PV x .8) that will give you rough AC Watts, and multiple the number of hours (typical US 6 or so) that will give you around the AVERAGE expected daily output.
/ Off grid solar system design help? #29
Me, I’d get as close to 440 watt, nominal 24v pv to charge a 12 v battery.
I would NOT risk hooking up more than the manufacturer maximum and hope for inefficiency. Should you blow the CC I doubt warranty would cover.
/ Off grid solar system design help? #30
Don't feel bad. :( I just wanted to charge lawn mower and atv batteries in our unpowered garage. Started out with a 75w which did something but not enough, so now I'm adding another 100w panel. Trees and snow are not your solar power friends. :LOL:
2019 Ram 1500 Pickup Truck (A64556)
2019 Ram 1500...
240 Massey Ferguson Tractor (A61165)
240 Massey...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
60ft. Truck Auger (A65640)
60ft. Truck Auger...
Skid Steer Rock Digger (A65640)
Skid Steer Rock...
Case skid steer wheels and tires (A63689)
Case skid steer...
