nylon bucket edge
/ nylon bucket edge #1
Steven
Peabody, Ma.
KUBOTA BX-22
Has anyone made or thought of making a nylon edge similar to a cutting edge on a snow plow that could be mounted to the loader bucket almost the same way a tooth bar is mounted on. I think this would help when you remove snow on a sealed driveway because it would not leave all those scrap marks. I have been throwing this idea around and may put one together to try it out for this winter (I know its only August but I like to think ahead) any comments or ideas are welcomed, or pictures if you may have made one.
/ nylon bucket edge #2
Unless you are a DuPont, I doubt anyone could afford the cost of a Nylon wear strip.
Airport snow removal equipment uses a rubber scraper blade, and the same idea could be applied to a loader bucket, or better yet, a snow pusher that fit in place of the bucket.
Using a loader on snow is only efficient in terms of gaining seat time.
/ nylon bucket edge #3
Not a bad idea, here are a couple of links of people who make the urethane edges. Might help get the ideas flowing.
http://www.cue-inc.com/page5.htm
http://www.snopusher.com/
Gordon
/ nylon bucket edge #4
Steven, I like your idea and have been considering doing the same. I plan to remove snow this winter with my new back blade but I know I will use the FEL in a few spots. I have a 400 ft concrete driveway and 30 x 70 slab in front of the garage. I was also thinking about putting gauge wheels on my back blade /w3tcompact/icons/smile.gif
/ nylon bucket edge #5
<font color=blue>"I was also thinking about putting gauge wheels on my back blade."</font color=blue>
Hey Jerry!
Here's an idea! Why don't you think about relocating your turn signals from your fenders up on the ROPS! /w3tcompact/icons/clever.gif
Now wouldn't that be a novel idea? /w3tcompact/icons/hmm.gif/w3tcompact/icons/laugh.gif
/ nylon bucket edge #6
/w3tcompact/icons/hmm.gif I feel you are toying with me /w3tcompact/icons/wink.gif
I'm going to send over a few of these to see you /w3tcompact/icons/mad.gif
/w3tcompact/icons/laugh.gif /w3tcompact/icons/laugh.gif
/ nylon bucket edge #7
<font color=blue>"I'm going to send over a few of these to see you."</font color=blue>
Yeow!! /w3tcompact/icons/shocked.gif
I give!! I give!!/w3tcompact/icons/frown.gif
/ nylon bucket edge #9
<font color=blue>"Play nice, or I'm gonna have to call a moderator to break it up!!!!"</font color=blue>
Awwww geesh! /w3tcompact/icons/frown.gif We don't get to have any fun anymore! /w3tcompact/icons/sad.gif/w3tcompact/icons/sad.gif
/ nylon bucket edge
Thanks Gordon. I never even thought of urathane blades, We have 4' x 8' sheets 1" thick nylon at work and figured I would grab a 4' x 6" piece and try it. but the urathane I think is a better approach. Thanks agian.
/ nylon bucket edge #12
Heck you never know you might be on to something by using the nylon. How rigid is it? Would you have to sandwich it? By getting longer bolts for your rear blade cutting edge, then let the nylon hang down a couple of inches below the blade and the metal cutting edge thus creating a sandwich. Just an idea.
Your quite welcome, hope it helps.
Gordon
/ nylon bucket edge #13
after seeing the links that Gordon posted I did some research,I contacted fallline and ask them to quote a custom urethane cutting edge for my WOODS RB60 rear blade. They were very helpful and even called to confirm some specifics to be sure they understood what it was I was looking for,and still got me a quote the same day. Please see the attachment for the drawing of the urethane edge. With the cost at $115.74 for 1" or $171 for 1.5" I feel that it is a reasonable price to minimize the risk of damaging my brand-new 3/8 mile asphalt driveway. As a Bonus, the claim is that urethane will out last steel when used on concrete or asphalt. I plan to use my rear blade for snow removal much more than my FEL, however they may very well be able to custom make a urethane cutting edge for the FEL. once the snow starts flying here in Pennsylvania this winter I will be sure to let you now how it works out. hope this helps
/ nylon bucket edge #14
If you are looking for something stiff, you might want to try a piece of UHMW plastic (Ultra High Molecualr Weight plastic). Where I used to work we nicknamed it "Poor Man's teflon". We used it in a lot of high wear area to protect the material we were handling (coils of steel wire) from abrasion damage. We lined the booms and forks on our fork lift trucks with it. Also used it as the business end of a drag brake on some of our payoff equipment. Held up very well (MUCH better than nylon or the types of urethane we tried), and pretty inexpensive. You can order various sized sheets or strips of it from several industrial supply paces (like Grainger or McMaster-Carr).
John Mc
/ nylon bucket edge #15
Another good choice would be H.D.P.E. high Density Polyethlylene (spelling?).
/ nylon bucket edge #16
the only problem I saw with this UHMW plastic is that it's not recommended for outdoor use, needs to be UV stabilized(?)
McMaster-Carr has a great website though. Loads of "cool" stuff.
gary
/ nylon bucket edge #17
<font color=blue>the only problem I saw with this UHMW plastic is that it's not recommended for outdoor use, needs to be UV stabilized(?)</font color=blue>
I hadn't considered that. We did use it on our outside forklift and boom lift trucks with good results, however. If your loader gets any degree of regular use, I'd figure you'd wear through it more quickly than the UV would degrade it. I think we settled on it in part because of price and in part because it seemed to wear better than some of the alternatives.
If my memory is correct, and it is significantly cheaper, it may be worth trying UHMW first. It would let you check out and refine your design (shape, attatchment method, etc.) while you were testing how it held up to UV. If UV resistance is a factor, you could upgrade to a more expensive alternative, but at least you would have worked out some of the other bugs first.
Are you storing the tractor/loader inside or out? That may also affect how much of a factor UV is for you. If it;s stored inside, and gets used a couple hundred hours a year, that's not much UV exposure.
John Mc
2022 Bautista Welding and Custom 40ft. 10 Ton T/A Gooseneck Flatbed Trailer (A61573)
2022 Bautista...
Kubota M125X (A60462)
Rake Master CR-72G (A64119)
Rake Master CR-72G...
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A59911)
2006 CHEVROLET...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2007 FREIGHTLINER M2 106 4X2 26FT BOX TRUCK (A59912)
2007 FREIGHTLINER...
