NX4510 tie rods
/ NX4510 tie rods #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
Looking for aftermarket inner and outer tie rods for my tractor. Has anyone changed theirs out yet.(update) Found a pair of Kioti tie rods on Ebay for $215.00 for the pair with free shipping. Kioti is $329.09 each. Today is my lucky day.
/ NX4510 tie rods #2
Hey Jim. Are you having problems with your tie rods? Curious why you are going to replace them. Thanks for your time.
/ NX4510 tie rods
Hi Dave, Both of my outer tie rods were never greased when made by ????? for Kioti. When I noticed play in my steering I took them out and popped the rubber boots off of the outers. They both were rusted up which caused them to wipe out prematurely. Now the inners are worn out. They were greased. I did check them after finding out that the outers were never greased. I did install grease fittings in the outers and tightened up the ball ends with a press. That was at least 2 years ago.
/ NX4510 tie rods #4
Ok, thanks for the info. I'll have to check mine as well. My loader valves were like that. No grease.
/ NX4510 tie rods
So sad to see that a simple task of adding grease before swedging a tie rod end cannot be accomplished.
2020 Case 5550 Trident (A61307)
2020 Case 5550...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A59230)
2000 Thomas Built...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A59904)
2012 INTERNATIONAL...
iDrive TDS-2010H...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
