CK25 HST Tie Rod Ends
/ CK25 HST Tie Rod Ends #1
rmahlert
Bronze Member
Central Massachusetts
Kioti CK25 HST
Anyone know of an aftermarket alternative for the tie rod ends on a CK25 HST? My local dealer is up there, plus, I need to pay for the UPS shipping from the warehouse for them.
Thanks,
/ CK25 HST Tie Rod Ends #2
What do you mean?
What’s the expected cost all in?
/ CK25 HST Tie Rod Ends #3
Michigan Iron Equip lists those for about $64 each. Don't know about shipping costs.
/ CK25 HST Tie Rod Ends #5
Flea bay is exactly that. Mostly cheap Chinese junk…
$64 for OEM sounds reasonable to me.
/ CK25 HST Tie Rod Ends #6
I disagree with your premise. Lots of good domestic stuff on Fleabay but you have to use discretion. Amazon is a different story... And not everything is cheap Chinese junk either. The Chinese, with proper oversight, can produce quality stuff like Milwaukee and DeWalt tools for instance.
/ CK25 HST Tie Rod Ends #7
I wouldn't be surprised if the OEM ones and most of the aftermarket ones are also chicom made. Chicom-child-slave-labor manufacturing is capable of making parts to spec if provided with proper oversight as 5030 mentioned above
/ CK25 HST Tie Rod Ends #8
Not sure about this brand but Kubota tie rod ends have no grease fittings installed in them, however, the 'aftermarket' ones do. I bought my last set from a Fleay Bay seller btw. Not that it's something I need to replace very often because I don't.
Finally, I sell some of my products on Flea Bay myself and they surely aren't made across the pond either.
/ CK25 HST Tie Rod Ends #9
Here is a link to Moog suspensions tie rod ends by size,
measure the taper and threads desired, cross reference the moog number to which ever brand you prefer.
https://www.moog-suspension-parts.com/universal_outer_tie_rod_ends.asp
/ CK25 HST Tie Rod Ends #11
Thanks for posting this info up Lou. I noticed today that both my inner and outer tie rods on my NX4510 are shot. Hopefully I can match them up with Moog parts. I'll also post up on the forum looking for info in case somebody already has found the part numbers. (Update) I just found a pair on Ebay for $215 for the pair with free shipping. Kioti was $329.06 for one side.
Yeehaw.
/ CK25 HST Tie Rod Ends #12
Thanks,
There are two sets listed on Ebay right now for $104.75 each.
