CK25 HST Tie Rod Ends
/ CK25 HST Tie Rod Ends #1
rmahlert
Central Massachusetts
Kioti CK25 HST
Anyone know of an aftermarket alternative for the tie rod ends on a CK25 HST? My local dealer is up there, plus, I need to pay for the UPS shipping from the warehouse for them.
Thanks,
/ CK25 HST Tie Rod Ends #2
What do you mean?
What’s the expected cost all in?
/ CK25 HST Tie Rod Ends #3
Michigan Iron Equip lists those for about $64 each. Don't know about shipping costs.
/ CK25 HST Tie Rod Ends #5
Flea bay is exactly that. Mostly cheap Chinese junk…
$64 for OEM sounds reasonable to me.
/ CK25 HST Tie Rod Ends #6
I disagree with your premise. Lots of good domestic stuff on Fleabay but you have to use discretion. Amazon is a different story... And not everything is cheap Chinese junk either. The Chinese, with proper oversight, can produce quality stuff like Milwaukee and DeWalt tools for instance.
/ CK25 HST Tie Rod Ends #7
I wouldn't be surprised if the OEM ones and most of the aftermarket ones are also chicom made. Chicom-child-slave-labor manufacturing is capable of making parts to spec if provided with proper oversight as 5030 mentioned above
/ CK25 HST Tie Rod Ends #8
Not sure about this brand but Kubota tie rod ends have no grease fittings installed in them, however, the 'aftermarket' ones do. I bought my last set from a Fleay Bay seller btw. Not that it's something I need to replace very often because I don't.
Finally, I sell some of my products on Flea Bay myself and they surely aren't made across the pond either.
/ CK25 HST Tie Rod Ends #9
Here is a link to Moog suspensions tie rod ends by size,
measure the taper and threads desired, cross reference the moog number to which ever brand you prefer.
https://www.moog-suspension-parts.com/universal_outer_tie_rod_ends.asp
/ CK25 HST Tie Rod Ends #11
Thanks for posting this info up Lou. I noticed today that both my inner and outer tie rods on my NX4510 are shot. Hopefully I can match them up with Moog parts. I'll also post up on the forum looking for info in case somebody already has found the part numbers. (Update) I just found a pair on Ebay for $215 for the pair with free shipping. Kioti was $329.06 for one side.
Yeehaw.
/ CK25 HST Tie Rod Ends #12
Thanks,
There are two sets listed on Ebay right now for $104.75 each.
HOMEADE 64" X 14' DOUBLE AXLE TRAILER (A60430)
HOMEADE 64" X 14'...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
KUBOTA SR2790 SKID STEER QUICK ATTACH ROCK RAKE (A60429)
KUBOTA SR2790 SKID...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
20800 (A56859)
20800 (A56859)
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
