Now ready for the concrete in the pole barn
   / Now ready for the concrete in the pole barn #61
I builty current shop using all metal conduit and boxes. Raplaced a previous shop that burned from unknown causes. My electrical supplier suggest metal conduit to reduce risk of electrical fire. If anything goes wrong and shorts within the system the metal condicts the short back to the main and trips the breaker.
I'm wiring my new shop the same way.
With metal conduit as you said eliminates the need to pull a ground wire ! I got pretty good at bending the pipe as the counties around Chicago where we used to live required every building to be run in metal conduit.
Got my concrete guy scheduled for this coming Friday ! He came out to look at the barn this morning. Going with 5" 4,000psi, fiber mesh and some rebar, saw cut expansion joints and trowel finish all for the low price of $4,600. It will be less if it doesn't take the 27 yds he quoted me, he just doesn't like to run short since the ready mix plant is 45 minutes away. He has been doing it for 30 years. I did have another concrete guy come out yesterday. He does mainly big parking lots, building slabs etc. He must have thought I had gold in my wallet....his price was $13,000 !!! There is only 1 ready mix plant in the area as we live somewhat remote in the mountains, which is why it is hard to find contractors or anyone with building skills to come out this far....so you pay alittle more for deliveries and skills. The concrete is $125.00 a yard and they consider anything less than 10 yds a 'light load' which adds a $125 fee if under 10 yds ! I have always paid light load fees for anything under 5 yds, but I have to remember where we live ! Got all the stone put in today, will rent a plate compactor on Monday to vibrate and pack it down.
   / Now ready for the concrete in the pole barn #64
I'm not an electrician, but I would be surprised if you can use the conduit in place of a ground wire.
   / Now ready for the concrete in the pole barn #65
If its available a little bit of water on the stone will help it compact better.
   / Now ready for the concrete in the pole barn #66
Prepare to be surprised!
   / Now ready for the concrete in the pole barn #67
Per the NEC, EMT can be used as an equipment ground.
   / Now ready for the concrete in the pole barn #68
So if you are doing radiant slab heat, what’s your plans for insulation? How are you forming for around the garage doors for the thermal break between outside and inside?
   / Now ready for the concrete in the pole barn #69
Look around your area for a place that needs a small walkway or entrance slab and get it prepared just in case there is extra concrete on the truck then you will have a place for it.
Wheelbarrow/tractor bucket ready too to move it if needed.
I always hated sending back a 1/4 - 1/2 yard!! You never really know how much is left in the truck either.
Yes, I have a side door entrance piece I am forming up and a few other small areas. Its your concrete so be ready to use it !!!
2016 Ford F-450 12FT Flatbed Truck (A55852)
2016 Ford F-450...
23091 (A55758)
23091 (A55758)
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
Adams 5 Ton HC Spreader (A55301)
Adams 5 Ton HC...
2011 Western Star Trucks 4900 Tri Axle Truck, VIN # 5KJNALDR4BPBA7822 (A54865)
2011 Western Star...
2000 POLAR TANK TRAILER TRANSPORT TRAILER (A55745)
2000 POLAR TANK...
