Not to Brag, but...
   / Not to Brag, but...
Most 3-point hitches have two settings for the links to the lower arms, one of which allows you to lift each one independently, maybe 4 inches higher than the other. Very useful for that scenario.
That said, I avoid ever putting any implement down on anything but level concrete or asphalt. Heck, I might even think twice about asphalt, in some cases. :ROFLMAO:
Somehow I was reading this as if both were hydraulically controlled independent of one another.
   / Not to Brag, but... #32
That would be cool! :ROFLMAO:
I guess those with top and tilt have that. I just have hydraulic top link, never had much use for tilt, for my applications.
You'd think with well over 100 years of tractors that would be available.
Which tells me how spoiled we are. Farmers did these things with horses and mules.
   / Not to Brag, but... #34
There's another thread just started on this forum, a guy buys 4 acres and is fixing to buy his first tractor. There's a thousand such threads on this forum, and you know what direction it's headed before it even starts, half this forum will try convincing the guy he needs to drop 50 large on a 40 hp CUT with an FEL and all the fixin's.
As I read these, I think of an uncle who spent his entire life on 85 acres, and never even owned a tractor. I think of two others who had large dairy farms, and never had more than two old Oliver and Bolens tractors that most would laugh at today. They wouldn't even know what to do with a modern 40 hp CUT. :D
   / Not to Brag, but... #35
It is available. There are tractors that even have hydraulic stabilizers along with the hydraulic side link. Typically available in specialized tractors for vineyards and orchards.
   / Not to Brag, but... #36
I went with having multiple tractors so I don't have to change stuff out. The WM75 has a 6' cutter for pastures, the WM25 has a 4' cutter for under the trees and small paddocks, and the TC40DA has the arena drag. If I need to swap implements it is usually the TC40DA that gets the nod.
My fault on this thread. My brush cutter is 5' not 6'.
I edited out my mistake on prior posts.
   / Not to Brag, but... #38
I've owned 3 Deere's (3033r, 855, 750), and all had two different positions for the pins on the connectors between the rockshaft arms and lower link arms, one of which allowed the lower links to float or lift independently.
On the 3033r, you just turn the lower link pins a quarter turn.
Floating:
Fixed:
Note the keyway slot type pin head is turned from vertical to horizontal. It's right there in the manual of every tractor I've ever owned, although the exact hardware used is slightly different on each.
Is this something only Deere does? I can't imagine having a tractor without this simple feature.
Pretty interesting setup but I have never noticed that before. It sure doesn’t appear that by turning that pin you would be able to lift one arm 4 inches higher than the other but because you would be measuring at the end of the arm maybe 4 inches would be possible.
My LS does give you 2 holes to choose from in the lower vertical arm, they are about 1 inch apart and the pins are bolts with self locking nuts, they are not even mentioned in the owners manual other than to say be extra careful if you remove them because the 3 point hookup parts are pretty heavy.
   / Not to Brag, but... #39
I've had this feature on every CUT I've owned, but they were all Deere, so maybe it's just a Deere thing. I honestly thought all tractors with 3 point hitch had this feature.
How does an implement like a plug aearator or even rear snowblower ride the terrain, if it's fixed to the rear axle attitude? Everything here is hilly, even our driveways and parking lots. :D
I didn't measure, but I'd guess it's probably pretty close to the 4" I claimed, at the end of the links. The slot is roughly 2" between centers, and positioned at roughly half the link arm length. But the exact inches of free play wasn't so much my point, as the fact that you can lift one link arm to meet the pin on an implement, after the other is already connected.
   / Not to Brag, but... #40
It was my second time hooking it up iirc. The shaft lined right up first try.
The first time I did it took a long time, and almost lost my salvation on that one.
TG, you just need to buy another tractor and keep the BH hooked up to it all the time.
Problem solved!
40' CONTAINER (A52706)
23105 (A56859)
23105 (A56859)
2017 Ford F550 Chassis (A55973)
2017 Ford F550...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2000 FORD F-350 SUPER DUTY (A58214)
2000 FORD F-350...
