not all front blades made equal?
/ not all front blades made equal? #1
Diesel_Boy
Central Maine
i've read on the forum that plowing the snow with a front blade on a tractor can be a risky thing because supposedly if the blade strikes something solid and immovable, it might bend the frame or something on the tractor. a friend of mine told me plows for trucks have a spring loaded strip at the bottom that will bend backward if it hits something. sometimes the whole plow will tilt backward. two part question:
is it true about bending something on the tractor with a front blade?
if so, is there any way to still plow with a tractor, with a third party blade made specially for this, or to modify the blade?
thanks,
diesel boy.
/ not all front blades made equal? #2
Lots of people modify truck mounted blades to fit a tractor. This gives you the spring protection you want. Curtis makes this style blade to hook up to your loader. The biggest problem is when people hook up a stationary blade to the loader then ram it into something that is footed rather well. This puts a lot of stress on the loader arms and can bend the loader arms themselves. As for the frame of a tractor. I would think the blade frame would bend before the tractor frame would but most tractors that I am around don't use frames anymore. The plow would bolt into holes designed into the tractors castings.
/ not all front blades made equal? #3
My JD front blade is a spring trip blade that can be either made stationary with pins or trip(hinge forward from the top) against the tension of springs when it strikes something. It a pretty standard design that should be copied if building your own.
2022 EZ-GO ELITE...
Patterson water pump (A59230)
Patterson water...
2004 CATERPILLAR 242 SKID STEER (A64279)
2004 CATERPILLAR...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
