not all front blades made equal?
/ not all front blades made equal? #1
Diesel_Boy
Central Maine
i've read on the forum that plowing the snow with a front blade on a tractor can be a risky thing because supposedly if the blade strikes something solid and immovable, it might bend the frame or something on the tractor. a friend of mine told me plows for trucks have a spring loaded strip at the bottom that will bend backward if it hits something. sometimes the whole plow will tilt backward. two part question:
is it true about bending something on the tractor with a front blade?
if so, is there any way to still plow with a tractor, with a third party blade made specially for this, or to modify the blade?
thanks,
diesel boy.
/ not all front blades made equal? #2
Lots of people modify truck mounted blades to fit a tractor. This gives you the spring protection you want. Curtis makes this style blade to hook up to your loader. The biggest problem is when people hook up a stationary blade to the loader then ram it into something that is footed rather well. This puts a lot of stress on the loader arms and can bend the loader arms themselves. As for the frame of a tractor. I would think the blade frame would bend before the tractor frame would but most tractors that I am around don't use frames anymore. The plow would bolt into holes designed into the tractors castings.
/ not all front blades made equal? #3
My JD front blade is a spring trip blade that can be either made stationary with pins or trip(hinge forward from the top) against the tension of springs when it strikes something. It a pretty standard design that should be copied if building your own.
2017 Chevrolet Tahoe SUV (A64557)
2017 Chevrolet...
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
2013 International WorkStar 7500 29Yd. Side Loader Garbage Truck (A64194)
2013 International...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
FORD 5 BOTTOM PLOW (A64278)
FORD 5 BOTTOM PLOW...
