Not Again! 4320 Axle Leak
/ Not Again! 4320 Axle Leak #1
ChrisJD4320
Shady Grove, PA
John Deere 4320
Yep. I moved the tractor tonight and on the floor was a nice puddle of axle fluid under the right front tire. The dealer fixed the same leak at 50 hours. Now I'm at 100 hrs and It's leaking again. What is up with the leaky front end? Is this common? I'm sure the dealer will fix again but will they get it right? I hope this isnt an every 50 hr thing.
/ Not Again! 4320 Axle Leak #2
Driving in deep MUD will break the seals and make them leak. I suppose driving in anything that would cover the seals may make them leak.
David
/ Not Again! 4320 Axle Leak #3
We fill ours with 85-90 wt gear oil instead of the hy-guard the book says to use, none have returned after this.
/ Not Again! 4320 Axle Leak #4
Given that this particular seal has failed before --- I'd ask the shop foreman to have the floor guys really give the axle surface a thorough check. You might have a scored or out of round axle that's eating up the seal after a few hours.
Heck, the seal's not even lasting to the next oil and filter change...
I'm running Mobil 1 synthetic 80-90w and it's probably even thinner than the lo-vis JD hy-guard. And (knock on forehead) I've got dry wheels!
Good luck with a long-term fix!
AKfish
/ Not Again! 4320 Axle Leak #5
remove the wheel and wash out the joint between the axel flange and axel housing and take a heavy piece of twine such as baleing twin or carpenters string and work around the gap, that may dislodge whatever may be holding the seal open
the front seals arn't hard to replace if they are anything like what is on my 4310, ive done 2.
/ Not Again! 4320 Axle Leak #6
Chris, Your situation sounds just like my 2520, now in the repair shop for the fourth time.. Hope you have better luck getting it fixed.
The dealer is working on my wheel seal today. I also am having them check the battery. I noticed the top of the Strongbox battery was wet and the bolts/metal are fuzzy from battery electrolyte. From reading on TBN it seems this is a common issue for alot of JD tractor owners.
/ Not Again! 4320 Axle Leak #8
I just ran into the same issue with my 4320. There's oil on the inside of the front-right hub and corrosion below the battery and on top of the pivot bracket for the front axle. The dealer mentioned that he's seen quite a few front axle seal leaks and that most turn out to be from paint on the flanges that compress the gaskets. Then on top of all that, I had a coolant leak a few weeks ago. I tightened up the hose clamps twice and no problems yet, hopefully it stays that way.
Too many leaks for a tractor with 60 hours.
/ Not Again! 4320 Axle Leak #9
David
So you should take care to keep your tractor out of mud? I can drive my wife’s mini-van through mud without it leaking. Seems like a tractor should be able to.
Checked with dealer today. They had to order a part from Syracuse, NY for my wheel seal. He didn't know what part it was. Regarding the battery he said the Strongbox is a vented battery and it's normal for it to leak fluid.
I dont like the sound of that at all. Battery acid will eventually eat the front of my tractor away! Shouldn't they put a SEALED battery in a bouncy tractor? Should I upgrade? My expense I'm Sure....
/ Not Again! 4320 Axle Leak #11
Yes, you should be able too drive a tractor through deep mud. Just talking from experience, have had both front knuckle seals replaced because of mud and I said pretty much the same thing to the Service Manager, What ya mean I can't dive in mud- it's a tractor:mad:
David
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
JLG 660SJ (A58214)
JLG 660SJ (A58214)
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
