Not a good start
/ Not a good start #21
So dealer ended up swapping out the machine. Unfortunately the second machine was doing the same thing. At this point I was very frustrated but luckily when I contacted the dealer the engineers from Japan were already at his dealership for some kind of conference. After they got the first machine back they started going over it they immediately found the problem and realize they were going to have to come up with a fix. It has something to do with some kind of spacer. I was very grateful that they found it cuz I was starting to think they were just thinking I was crazy. At this point I'm just waiting for them ,they are sending somebody out to my house to fix it. Yanmar was really nice and they were very appreciative that I kinda help them find an issue. After the fix i will get back to everybody
Wow, that’s a very impressive response. Care to share which dealership this was? Pm maybe, if here is against the rules.
/ Not a good start
Update. Dealer sent me the part to replace. In the end the 25 dollar part didn’t fix the issue instead It cost me $4000. When I got finished I started the tractor and the backhoe Went right through the garage door. I Forgot to put the seat backdown for the backhoe, and the seat was pushing on the controls. Talked to dealer waiting On response from them and Yanmar. I have a few questions when the machine is running do you hear the transmission Whine When you take the Break off and on? I noticed on mine You will periodically hear that whining ,specially if you pull into like a pile of stone and have a load on the engine. Is that all normal? Also When shifting forward and reverse can it sometimes be harsh when it shifts? I noticed if I come to a stop but the Brakes on and then shift it’s fine, but Sometimes when you’re moving and you should forward reverse it seems harsh? let Me know thanks
/ Not a good start #23
I dont think the dealer new anything. The only reason i say they that because they are 12 hours away from me and thats a pretty big risk for them to take. Only thing that does have me scratching my head, is the dealer said on the sheet that follows the tractor they have it listed at like 0.9 hours on the machine. When I recieved the machine it had alittle over 2.5 hours on it. I put about hour on when I called them
12 hours? Jeez I used to leave Raleigh NC and make Miami Florida in 11.5 hours. Your Dealer performed what I call a service call.
/ Not a good start #24
Yanmar makes outstanding machines, but their US dealer network is sparse indeed.
/ Not a good start #25
Wow. That's a terrible turn of events. This unit is the one folks have also had recurring issues with the steering being sluggish with a loaded bucket, and Yanmar is still working on that issue to my knowledge
/ Not a good start
Update. I have 87 hours on machine and 3 leaks. 2 in the rear and the left front axle. Not to happy. Ive been dealing with the dealer for 2 months to get it fixed. Anybody else have leaking issues?
/ Not a good start #27
I was ordering YT359c this week but now I'm rethinking that decision.
/ Not a good start #28
Maybe ask to try at your place first to see if some of these issues pop up?
/ Not a good start #29
This is not a common issue. As is with anything that is manufactured, you will have failures, some manufacturing, some abuse by the end user. Not sure what the issue is with the axle leak without looking at it, but it isn't common.
/ Not a good start #30
Never owned ANY tractors that didn't leak a little and both mine (I own 2 presently) leak a bit. I ignore it as hydraulic fluid is inexpensive and so is motor oil. They are tractors after all and not Rolex watches (I have one of them as well).... Even my Rolex requires timely servicing.
/ Not a good start #31
Axle seal and collar which I had to replace on my Yanmar Decades ago. The collar itself is pressed on the axle shaft. I have a new Collar also but at the time I opted to leave it and not replace it with the new collar. Microscopic small pitting and Yes it still drips a very little and pretty much what yours looks like. Not worth the couple drips Of Hyd. fluid after use and parking it. Never had to add any hyd. fluid in 15yrs. it's so pitiful.
/ Not a good start #32
Very unfortunate. I have had no issues on my 2017 and have almost passed 800 hours now. My only complaint is the darn transmission filters are so darn expensive. My only major expense has been the right side door glass. It was shattered by a run away stone. Scared the sh_t out of me. Thought someone had shot at me when I was flail mowing a forage field in the fall. Turned out I had hit a vole nest that the local fox had excavated. Fox left a mound that was hidden in the grass. One of my flail mower flaps was stuck in the open position allowing said rock to get launched. The whole door glass was shattered into tiny bits no bigger than the end of a tooth brush. $1000.00 for a new door glass but I installed it myself and now run with a clear plastic tractor door guard when flailing just in case.
/ Not a good start #33
What us a clear plastic door guard? Something you finagled or ?
/ Not a good start #34
Custom made in the UK. See them here: Tractor Guard - US Farm Innovations
I run the rear window and the right hand side window guards. Flail is a FARC Master 1600 which has right side offset and vertical tilt for hedge rows so lots of potential for airborne objects if the flail flaps don't do their job properly.
2014 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A65056)
2014 CATERPILLAR...
2018 JOHN DEERE 350G LC EXCAVATOR (A65053)
2018 JOHN DEERE...
2019 JOHN DEERE 750K LGP CRAWLER DOZER (A65056)
2019 JOHN DEERE...
PORTAPOTTY (A67714)
PORTAPOTTY (A67714)
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
SKIDED FUEL TANK (A67714)
SKIDED FUEL TANK...
