noob snowblower question
   / noob snowblower question #2
Anything labeled "shearbolt" I see #19 on page 12 of that manual.
   / noob snowblower question #3
I have owned this type and size blower, a good machine. Keep spare shearbolts and nuts on board. I went full years without breaking one, then broke one every 3 hours for a while. So whatever the book says, have them in the correct grade. Keep the wrenches in your tool box too.
   / noob snowblower question #4
Item 71 on page 21 of the manual....shearbolt for the pto shaft. If you are already breaking them, I would drill it out to a 1/4" which is only .014" larger and use a grade 5 bolt about 1 5/8" long.
   / noob snowblower question #7
i guess I'm lucky, only broke 1 shear bolt in 14 years and thats because I tried to snowblow 2 inch layer of ice.
   / noob snowblower question #8
If the blower is brand new, let it run on the tractor for a 1/2 hour, then grease it up again. New assemblies take a little time to wear in, shearing bolts would be reduced. Don't put a higher rated bolt in, it just moves the failure to another shear bolt that will be harder to access. Engage the PTO with the blower lowered, doing it while raised puts additional stress on the PTO shaft shear bolt.
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2005 International 8600 Hydro Vac Truck (A50860)
2005 International...
JCB 505-TC 4x4 Rough Terrain Telehandler (A49461)
JCB 505-TC 4x4...
2021 John Deere R4038 Self Propelled Sprayer (A50657)
2021 John Deere...
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
