noob snowblower question
   / noob snowblower question #2
Anything labeled "shearbolt" I see #19 on page 12 of that manual.
   / noob snowblower question #3
I have owned this type and size blower, a good machine. Keep spare shearbolts and nuts on board. I went full years without breaking one, then broke one every 3 hours for a while. So whatever the book says, have them in the correct grade. Keep the wrenches in your tool box too.
   / noob snowblower question #4
Item 71 on page 21 of the manual....shearbolt for the pto shaft. If you are already breaking them, I would drill it out to a 1/4" which is only .014" larger and use a grade 5 bolt about 1 5/8" long.
   / noob snowblower question #7
i guess I'm lucky, only broke 1 shear bolt in 14 years and thats because I tried to snowblow 2 inch layer of ice.
   / noob snowblower question #8
If the blower is brand new, let it run on the tractor for a 1/2 hour, then grease it up again. New assemblies take a little time to wear in, shearing bolts would be reduced. Don't put a higher rated bolt in, it just moves the failure to another shear bolt that will be harder to access. Engage the PTO with the blower lowered, doing it while raised puts additional stress on the PTO shaft shear bolt.
2025 25ft. 800Amp Extra HD Booster Cables (A48081)
2025 25ft. 800Amp...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
International 574D Tractor (A50860)
International 574D...
2001 International 3800 4X2 School Bus (A50860)
2001 International...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2015 MACK GRANITE DAY CAB (A50854)
2015 MACK GRANITE...
