no tach
/ no tach #1
woodmills1
hudson, NH
kioti LK3054
the tach on my 3054 quit, anyone know what might be up. I don't know too much about how a deisel gets its tach signal.
/ no tach #2
Hmmm...how the tach works. I don't know but my wife did get me the factory service manual for Christmas. It is for the 3504, but the 3054 will be the same. I can take a look, but probably won't be able to post intil tomorrow. You should have the parts manual and looking at it may provide clues to the tachs operation.
Miklos
/ no tach #3
Probably the cable stripped out the inside of the tachometer.
Tachometer will have to be replaced but it is easy, takes a small and medium phillips screwdrivers and about 15 minutes of your time.
Its not uncommon.
K
/ no tach #4
The repair manual lists the following:
Engine Tachometer Does Not Function When Engine is Running:
Tachometer cable is defective or improperly connected- repair or replace.
Hour meter assyembly defective- replace
Gear in instrument panel defective- replace
I know, not a lot of help, but thats what is listed in the factory sevice manual.
Miklos
/ no tach
problem solved. broken cable parts ordered and in the mail.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
UNUSED IREV HIGH-END 2 WHEEL ELECTRIC VEHICLE (A64281)
UNUSED IREV...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
2022 EZ-GO ELITE...
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
