No power anywhere
/ No power anywhere #1
david7w5
John Deere 4100sub
JD 4100 compact, I was grading the driveway and tractor shuts off. No power anywhere. Battery has voltage and Amp also tested good. The 4 fuses under hood is good. Any help would be appreciated
/ No power anywhere
Tight on frame and battery
/ No power anywhere #5
What's the multi meter say at the fuse box? Ignition? Sounds like a loss of ground somewhere to me.
/ No power anywhere #6
Seat switch???
/ No power anywhere #9
fuseable link in the 4100? not near my 4700 manual to see . is the ground dirty at all? I'd start looking at all connections and connectors.
/ No power anywhere
Fusible link is good, per meter
/ No power anywhere #11
don't just tighten ground, remove both ends and clean well, especially tractor end
/ No power anywhere #13
Congrats, but that's why I always make sure of hots & grounds before tearing into anything else.
Unverferth 6225 (A64119)
Unverferth 6225...
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
Mini rock grapples (A61567)
Mini rock grapples...
CASE TV380 SKID STEER (A64279)
CASE TV380 SKID...
UNUSED KUBOTA 48" PIN ON BUCKET (A64280)
UNUSED KUBOTA 48"...
