No more turnbuckles!
/ No more turnbuckles! #1
kubotajoe
New Hampshire
Kubota B7500
I have always wanted to get rid of those miserable 3ph arm adjusting turnbuckles after seeing this setup on Tim 8561's tractor. Ronnie Bowman at Tractorsmart knew exactly what I needed and I had the parts in just a few days. Here is a picture of the new installation on my B7500:
/ No more turnbuckles! #2
Nice, Joe! I'd like to order a set for the B7610. Do they have a part number? Do you have a link to a page that lists them? If you don't mind my askin', how much did they cost?
Bob
Hi Bob-
Sorry, I don't have a link or part numbers. I just called Ronnie at Tractorsmart and told him I needed all the parts for the telescoping adjusters like comes on a B2710 or B2910. The cost was $125.40 plus $8.60 UPS to NH. I don't know if they are a direct replacement for a B7610 but Ronnie will probably know.
Sure is nice not having to deal with those pesky turnbuckles. The telescoping adjusters stay spread while backing up to an implement.
/ No more turnbuckles! #4
That looks great, I know what you mean about the turnbuckles on the B7500. I still have turnbuckles but they are on the outside and much easier to work with.
/ No more turnbuckles! #6
There were several threads a couple of years ago about using those 2910 turn buckles on the BX22. A lot of BX owners made this simple modification and it worked fine.
/ No more turnbuckles! #7
With the pins rather then the turnbuckles do you pick up some swing (play) like from side to side?
/ No more turnbuckles! #8
Morning Joe.
Looks good,and yes indeed those turn buckles can be pain,more soo if they get bend or the link....wonder if your setup would fit on B7100.
/ No more turnbuckles! #9
Here you go. Here is a list of parts for the B7610. The B2910 is a direct replacement. Many thanks go to Dan for providing the pdf file.
I have not done the conversion yet, but its on my list. :D
  • B7610 Telescoping 3PH Arm Parts.pdf
/ No more turnbuckles! #10
I can confirm they also work well on the BX 2200, MUCH better then the turn buckles. Requires a little modification, grinding the ends if I recall, but an easy conversion. The cost has sure gone up, I think it was less then $75 a few years ago.:mad:
/ No more turnbuckles! #12
Milkman - was there any mods needed?
I have a 2350, wondering what the install might look like...
Curt
/ No more turnbuckles! #13
/ No more turnbuckles! #15
The only thing left for you to change is the pins that Kubota supplies with those arms. I have the type that have the bail wire attached and all you do is to insert the pin and pull the bail wire over the end. I like them better, since the are faster than dealing with cotter pins. I made the change over a few years ago and it has worked flawlessly on my BX22. Only wish that it didn't have to be removed to install the backhoe. :(
/ No more turnbuckles! #16
Maybe a stupid question from a newbie, but wouldn't a Quick Hitch connected to the original 3pt be a simpler solution?
2019 CAT 305E2 CR Mini Excavator (A62613)
2019 CAT 305E2 CR...
211298 (A62131)
211298 (A62131)
2022 EZ-GO ELITE...
LANDPRIDE FDR1648-48" FINISHING MOWER (A64280)
LANDPRIDE...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A63689)
Midwestern...
APPROX (50) 1" X 8" X 12' ROUGH CUT PINE (A64281)
APPROX (50) 1" X...
