No more turnbuckles!
/ No more turnbuckles! #1
kubotajoe
New Hampshire
Kubota B7500
I have always wanted to get rid of those miserable 3ph arm adjusting turnbuckles after seeing this setup on Tim 8561's tractor. Ronnie Bowman at Tractorsmart knew exactly what I needed and I had the parts in just a few days. Here is a picture of the new installation on my B7500:
/ No more turnbuckles! #2
Nice, Joe! I'd like to order a set for the B7610. Do they have a part number? Do you have a link to a page that lists them? If you don't mind my askin', how much did they cost?
Bob
Hi Bob-
Sorry, I don't have a link or part numbers. I just called Ronnie at Tractorsmart and told him I needed all the parts for the telescoping adjusters like comes on a B2710 or B2910. The cost was $125.40 plus $8.60 UPS to NH. I don't know if they are a direct replacement for a B7610 but Ronnie will probably know.
Sure is nice not having to deal with those pesky turnbuckles. The telescoping adjusters stay spread while backing up to an implement.
/ No more turnbuckles! #4
That looks great, I know what you mean about the turnbuckles on the B7500. I still have turnbuckles but they are on the outside and much easier to work with.
/ No more turnbuckles! #6
There were several threads a couple of years ago about using those 2910 turn buckles on the BX22. A lot of BX owners made this simple modification and it worked fine.
/ No more turnbuckles! #7
With the pins rather then the turnbuckles do you pick up some swing (play) like from side to side?
/ No more turnbuckles! #8
Morning Joe.
Looks good,and yes indeed those turn buckles can be pain,more soo if they get bend or the link....wonder if your setup would fit on B7100.
/ No more turnbuckles! #9
Here you go. Here is a list of parts for the B7610. The B2910 is a direct replacement. Many thanks go to Dan for providing the pdf file.
I have not done the conversion yet, but its on my list. :D
  • B7610 Telescoping 3PH Arm Parts.pdf
/ No more turnbuckles! #10
I can confirm they also work well on the BX 2200, MUCH better then the turn buckles. Requires a little modification, grinding the ends if I recall, but an easy conversion. The cost has sure gone up, I think it was less then $75 a few years ago.:mad:
/ No more turnbuckles! #12
Milkman - was there any mods needed?
I have a 2350, wondering what the install might look like...
Curt
/ No more turnbuckles! #13
/ No more turnbuckles! #15
The only thing left for you to change is the pins that Kubota supplies with those arms. I have the type that have the bail wire attached and all you do is to insert the pin and pull the bail wire over the end. I like them better, since the are faster than dealing with cotter pins. I made the change over a few years ago and it has worked flawlessly on my BX22. Only wish that it didn't have to be removed to install the backhoe. :(
/ No more turnbuckles! #16
Maybe a stupid question from a newbie, but wouldn't a Quick Hitch connected to the original 3pt be a simpler solution?
Paladin 12in Digging Tooth Bucket Excavator Attachment (A64194)
Paladin 12in...
2015 Hyundai VC2530152 53ft. T/A Dry Van Trailer (A61573)
2015 Hyundai...
APPROX (20) 1" X 8" X 12"' & (30) 1" X 8" X 10' (A64281)
APPROX (20) 1" X...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
Unverferth 6225 (A64119)
Unverferth 6225...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
