no lights on trailer
/ no lights on trailer #1
747driver
Tellico Plains,TN
Kioti CK27 HST
Ok...getting the trailer ready to go pick up new tractor and when i plugged the trailer to the truck....no lights.
When i metered the truck connector i am only showing .15 volts from the battery, all the rest of the pins show 0 voltage. Only thing that works is the electric trailer brakes. Took ground off and cleaned connection no help. Could not find any blown fuses.
2010 f150 with 7 prong connector
thanks
/ no lights on trailer #3
You have separate fuses for the trailer circuit on your truck. Check the fuses again.
Chris
/ no lights on trailer #4
When you tested the truck connectors where did you ground the meter? If the trailer, then the ground may be it. If you put a jumper cable between the truck and trailer and things start working then you know it's a ground problem.
/ no lights on trailer #5
What Chris said. You probably have a second fuse box possibly under the hood or inside right kick panel and trailer light fuses will be there.
Chris
So i went to the ford dealer out of frustration !! He said....have you checked the fuses and i said yes. So he doubled checked for me with a tester.....sure enough, 2 of the 20 amp mini fuses were blown !! Somehow my tri-focal glasses missed it ! The mini fuses act as a safe guard for the big relays and shutoff power to the truck connector in the back. They only charged me for the 2 fuses....great ford dealer. I think this all started from one of the reat trailer lights getting smashed, must have shorted out to the frame. Everything is back up and lighting as required. Now to go get my new tractor tomorrow and take it to Tenn.
Thanks everyone for the help.
Chuck
2016 CATERPILLAR CT660 SBA 6X4 DUMP TRUCK (A63276)
2016 CATERPILLAR...
2016 Ford Transit 350 Wagon Passenger Van (A64556)
2016 Ford Transit...
2013 Mack CXU613 T/A Day Cab Truck Tractor (A64556)
2013 Mack CXU613...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
2011 UD Thermoplastic Truck (A64194)
2011 UD...
