No, I'm the IDIOT!
/ No, I'm the IDIOT! #1
Turfman
South Weber Utah
Kubota B2710
No, I\'m the IDIOT!
Trucked my tractor (Rising Sun) up the canyon the other day for a job. Everything went smoothly. I brought it home and took it off the trailer at night. As I walked by the other day I noted that the clevis I used to chain her down was still on the draw bar. I told myself I needed to take it off and hurried off to a job I was doing. Well, I jumped on her to do a little job for my niece. Went down and moved some dirt and tonight I noted that the clevis had turned and was under the three-point stabilizer for the left side. Took a closer look and sure enough the stabilizer was bent. All the connections looked to be ok, but now it's $50 or $75 to replace the parts. Just can't get ahead. Good thing there's no law for tractor abuse. She is due for her 50 hour and I need to mail order the parts so my dealer doesn't know what an IDIOT I am.
/ No, I'm the IDIOT! #2
Re: No, I\'m the IDIOT!
Call me idiot #2. I have a grill guard on my JD 950 which rotates forward and rests against the FEL when I need to raise the hood. Well the last time I had my hood up, when I put it back down, I forgot to raise the guard back up. I cut some brush, loaded it on the FEL, took it to the burn pile, raised the FEL, dumped the brush, backed up, turned around, started back to the brush area. I could not see that when I raised the FEL, the guard rotated down to the ground. The guard caught on the ground, bent back under the tractor, broke the tension pins holding it. /w3tcompact/icons/blush.gif Amazingly enough, the guard was only slightly deformed. The brackets were only slightly bent. And I could find no damage to the underside of the tractor. I straightened the guard and brackets. Got some new pins and reattached it and never told anyone. Until now that is. /w3tcompact/icons/smile.gif
Bandit 200XP Wood Chipper (A63689)
Bandit 200XP Wood...
0.75yd. Concrete Bucket (A65640)
0.75yd. Concrete...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
Aluminum Turtle (A65583)
Aluminum Turtle...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
2005 Ford F-450 Dump Truck, VIN # 1FDXF46P65EB16866 (A65563)
2005 Ford F-450...
