No glow plug light
/ No glow plug light #1
shyster57
2007 dx45
Any help with possible fixes would be greatly appreciated
/ No glow plug light #2
Welcome to TBN. You're more likely to get possible fixes with more information about symptoms and any possible troubleshooting you've done thus far. Including the specific tractor and model would be most helpful, too.
/ No glow plug light #3
This for sure. The problem could be anything from a $1 burned-out bulb to a $3000 failed controller. My guess is either the bulb or hungry mice moved in behind the dash.
/ No glow plug light #4
Most glow plugs circuits have a relay or solenoid that is worked by a signal from the ignition switch. The relay/solenoid closes to allow the high amperage from the battery to go directly through the glow plug fuses and then to the glow plugs themselves. It also turns on the glow plug light at the same time.
I would check your glow plug fuses and consider replacing the glow plug relay(s). Those two items age faster and go wrong much more often than the rest of the glow plug system.
luck beats knowledge,
rScotty
2015 Ford F-150 Ext. Cab Pickup Truck (A61573)
2015 Ford F-150...
2015 HYUNDAI HX220L EXCAVATOR (A64279)
2015 HYUNDAI...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
2019 Volvo VNR64T T/A Sleeper Cab Truck Tractor (A61573)
2019 Volvo VNR64T...
