No glow plug light
/ No glow plug light #1
shyster57
2007 dx45
Any help with possible fixes would be greatly appreciated
/ No glow plug light #2
Welcome to TBN. You're more likely to get possible fixes with more information about symptoms and any possible troubleshooting you've done thus far. Including the specific tractor and model would be most helpful, too.
/ No glow plug light #3
This for sure. The problem could be anything from a $1 burned-out bulb to a $3000 failed controller. My guess is either the bulb or hungry mice moved in behind the dash.
/ No glow plug light #4
Most glow plugs circuits have a relay or solenoid that is worked by a signal from the ignition switch. The relay/solenoid closes to allow the high amperage from the battery to go directly through the glow plug fuses and then to the glow plugs themselves. It also turns on the glow plug light at the same time.
I would check your glow plug fuses and consider replacing the glow plug relay(s). Those two items age faster and go wrong much more often than the rest of the glow plug system.
luck beats knowledge,
rScotty
2013 Ford F-350 Knapheide Service Truck (A61573)
2013 Ford F-350...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
2015 Nisan Altima S Sedan (A61574)
2015 Nisan Altima...
2023 John Deere 8R 340 Tractor (A63111)
2023 John Deere 8R...
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
