No down force on John Deere loader bucket - 3005 tractor
   / No down force on John Deere loader bucket - 3005 tractor #1
John Deere 3005
Bucket lifts and loads fine, but no down force to back drag or lift front end. Just acquired, checked Hydro fluid level and it appears to be over filled. Could that be the problem?
   / No down force on John Deere loader bucket - 3005 tractor #2
Your not putting it float are you? There is a notch all the way forward that puts it in float.
If it has quick connect for the loader you can disconnect and reconnect them. Sometimes they look connected but aren’t seated all the way.
If the hydraulic is overfilled I’d drain a little.
   / No down force on John Deere loader bucket - 3005 tractor #3
Bucket has single action cylinder, no power down, but when you tilt with the bucket laying on the ground it can actually lift the front tires off the ground. Tilt has a double actiom cylinder,
   / No down force on John Deere loader bucket - 3005 tractor #4
No bucket cylinder that I've ever seen is single acting IE all FEL bucket cylinders were double acting
   / No down force on John Deere loader bucket - 3005 tractor #5
It would help you get more correct answers if you would reveal tractor & frt end loader models!! Are you referring to a JD 3005 & JD FEL? Are you 100% positive you're not placing boom control spool in float position??
   / No down force on John Deere loader bucket - 3005 tractor #6
no, I don't think overfilling is the problem... mine was overfilled from the dealer when I got it as well .... on mine (not a JD) if I go too far down too far on the joystick it will not apply force its like the de pressurize zone, play with it without going all the way to the end on the joy stick.
   / No down force on John Deere loader bucket - 3005 tractor #7
I had an old Super M that had only lift function, Only one hyd line to the lift cylinders. Baled a lot of hay with that M, including round bale transport with FEL. tilt was 2-way though.
Bobcat T66 (A60462)
Bobcat T66 (A60462)
Rhino DB150 (A57148)
Bobcat 435 FastTrack (A60462)
Bobcat 435...
KUBOTA GR2100 RIDING LAWNMOWER (A60430)
KUBOTA GR2100...
2012 FREIGHTLINER CASCADIA SLEEPER (A59905)
2012 FREIGHTLINER...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
