No down force on John Deere loader bucket - 3005 tractor
   / No down force on John Deere loader bucket - 3005 tractor #1
John Deere 3005
Bucket lifts and loads fine, but no down force to back drag or lift front end. Just acquired, checked Hydro fluid level and it appears to be over filled. Could that be the problem?
   / No down force on John Deere loader bucket - 3005 tractor #2
Your not putting it float are you? There is a notch all the way forward that puts it in float.
If it has quick connect for the loader you can disconnect and reconnect them. Sometimes they look connected but aren’t seated all the way.
If the hydraulic is overfilled I’d drain a little.
   / No down force on John Deere loader bucket - 3005 tractor #3
Bucket has single action cylinder, no power down, but when you tilt with the bucket laying on the ground it can actually lift the front tires off the ground. Tilt has a double actiom cylinder,
   / No down force on John Deere loader bucket - 3005 tractor #4
No bucket cylinder that I've ever seen is single acting IE all FEL bucket cylinders were double acting
   / No down force on John Deere loader bucket - 3005 tractor #5
It would help you get more correct answers if you would reveal tractor & frt end loader models!! Are you referring to a JD 3005 & JD FEL? Are you 100% positive you're not placing boom control spool in float position??
   / No down force on John Deere loader bucket - 3005 tractor #6
no, I don't think overfilling is the problem... mine was overfilled from the dealer when I got it as well .... on mine (not a JD) if I go too far down too far on the joystick it will not apply force its like the de pressurize zone, play with it without going all the way to the end on the joy stick.
   / No down force on John Deere loader bucket - 3005 tractor #7
I had an old Super M that had only lift function, Only one hyd line to the lift cylinders. Baled a lot of hay with that M, including round bale transport with FEL. tilt was 2-way though.
Wolverine Hydraulic Tiller Skid Steer Mount (A47371)
Wolverine...
2015 Toyota Tacoma 4x4 Ext. Cab Pickup Truck (A46684)
2015 Toyota Tacoma...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A45678)
2019 PETERBILT 579...
2017 Toro GroundsMaster 7200 72in Zero Turn Mower (A46684)
2017 Toro...
High Volume 84in. Bucket (A49339)
High Volume 84in...
KOMATSU PC360LC-11 (A48992)
KOMATSU PC360LC-11...
