Loader Nimco Controls
   / Nimco Controls #21
I ended up having to take the controls right off the tractor. here are some pictures. The right side is jammed and wont move without excessive force. There is a picture of the back end as well. Would I have to take this apart to get to the springs?View attachment 615949View attachment 615949View attachment 615952
The springs are under the caps on the end. There shouldn't be any fluid under the caps either. You take the caps off and can inspect the springs.
   / Nimco Controls #22
I haven’t seen the person who did the damage in any of the photos........
   / Nimco Controls
Hes camera shy
   / Nimco Controls
Thanks, I will look at it when I get back from vacation. Thanks for all your help.
   / Nimco Controls #25
Also, the right one has some tool marks on the polished surface....clean those up before you attempt to pull the valve through the seal.
   / Nimco Controls #26
My last backhoe developed a slight leak and would fill the caps with fluid. When that happened the rod couldn’t extend into the cap. I had the drill a hole in the cap to let them drain. But I doubt that’s the problem here.
   / Nimco Controls
So turns out the spool is bent. Anyone try to bend this back before? Not sure if I need to order a new one.
   / Nimco Controls #28
I'm sure it could be done. The handy tools would be an arbor press, v-blocks, and dial indicator.
   / Nimco Controls #29
That surprises me. Take the spool to a good hydraulic supply store and ask if they can match it up for you. The one I use locally has actually machined spools for different applications. They have hundreds of different spools in stock as well. Should be reasonable in price.
   / Nimco Controls
So I will give you guys the rundown. I brought the spool to a hydraulic shop and they didn稚 have any on hand and didn稚 want to try to bend the original back. Saying 的 will not even touch that? Said he could order one on Monday. So, with nothing to lose we decided to try and bend it back. A few attempts with the press and it slides in and out like it use to. Put it all back together, nothing leaks and it works great. My neighbor who did it by accident helped which was good on him. Thanks for everyone痴 help and I leant a lot from this experience. Glad I registered to the site.
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
Push Mower (A59231)
Push Mower (A59231)
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2019 CHEVROLET SILVERADO 11FT FLATBED (A59575)
2019 CHEVROLET...
44052 (A55852)
44052 (A55852)
John Deere 1025R (A53317)
John Deere 1025R...
