Snow Equipment Owning/Operating Newbie plow tripping
/ Newbie plow tripping #21
I just plow gravel and once the ground freezes, float works OK. If the ground isn't frozen, it makes a mess in float. I got a 1" thick by 10" wide rubber strip and attached it to the blade so as much as possible of the rubber hangs down. I set the loader down to put pressure on the rubber and have it bend backwards about midway so I have a few inches up and down leeway as I plow and not have to use float. Works great on unfrozen gravel.
Anyway, I need a bigger blade for my MX since this one is for my L3901 and will get one that floats off the SSQA plate which should make it better for gravel use.
2013 Case 850L (A60462)
2013 Case 850L...
Giyi XKH39 (A60463)
Giyi XKH39 (A60463)
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
Trimble Guidance System (A60462)
Trimble Guidance...
