New Yanmar
/ New Yanmar #1
runningbird
Gisela, AZ
yanmar 1110d ,fx28d
Found a FX28d at a JD dealer. Bought it sight unseen. I was told the 3pt system did not work and it had a large hydraulic leak. But that the motor ran strong. I already have a FX28d with a loader and will keep this one loader free for my Daughter to use with her business. Anyway took about 10 seconds to fix the 3pt system. The leak will be a bit harder but fixable. Tractor runs great.
Not bad for $2500
/ New Yanmar #3
What was wrong with the 3-point, and how did you fix it?
/ New Yanmar
at one point this tractor had a loader on it. they cut the pressure line to hook up the loader. That was UN-necessary has this model has a pressure and return hook up under the right foot rest. There is a lever under the seat that diverts flow to those hook ups. at some point they took the loader off and to make things work hooked a hose up to the 3pt system and moved the lever to divert.
I simply swapped the hose to where it belongs and moved the lever to open and all worked. I figured this was the case soon has I started it up and it was lugging, But the UFO side lift still worked.
/ New Yanmar #6
Thank you for the explanation. A basic plumbing problem indeed that you quickly solved. Congrats and best tractoring!
2012 International Prostar (A63118)
2012 International...
2018 SHERP PRO1000 AMPHIBIOUS ALL TERRAIN VEHICLE (A63276)
2018 SHERP PRO1000...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
2020 CATERPILLER 326 EXCAVATOR (A65053)
2020 CATERPILLER...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
24 Gauge R Panels (A65640)
24 Gauge R Panels...
