New to Quick Hitches - What do I need?
   / New to Quick Hitches - What do I need? #21
Modifications should be done to whatever is out of specs, even if it means a little more work. Specifications have been out for years but I still see new implements that don't meet them.
Quick hitch specs
Implement specs
Bruce
   / New to Quick Hitches - What do I need? #22
Thank you bcp,
I appreciate you taking the time to post those diagrams. I know it will save me (and hopefully some others) a lot of time having this info beforehand.
   / New to Quick Hitches - What do I need? #23
Unfortunately, Bruce is right, it seems that no one pays the slightest attention to the standards. On my new QH from Rural King (NOT the Speeco as indicated, but a Chinese "Country Way") the "N" dimension between the lower and upper hooks that is supposed to be 14.78 to 14.88 in. is ADJUSTABLE. Think that it can be adjusted to 14.78-14.88? Nope! 15 in to 18-1/8 in.!
:mur:
   / New to Quick Hitches - What do I need? #24
I am also having to modify implements (bushhog and box blade) fairly extensively to play nicely with said cheap Chinese QH. I'm attempting to do so in such a way that they can be easily retrofitted to again use with "regular" Cat 1 7/8" lift pins and 3/4" top pins so that my FIL or BILs could use my implements with their non-QH tractors. Further constrained by attempting to configure both implements with identical "N" spacing so as to not need to adjust the QH once I get everything set.
So far have had to extend the top hook by 1" as others have discussed in similar threads on here, am relocating the top pin support struts on both, and reversing the swinging top connection for the top pin connection on the Bush Hog. Plus adding all the bushings to go from at least Cat 1 to Cat 2. Although the QH hooks appear to actually be Cat 3 sized.
Ordered a bunch of bushings from Amazon (various suppliers), including two sets of the shouldered lift pin bushings (Northern Tool). Although I don't think I can use them on the Bush Hog because the existing pins are already 27 - 1/8" wide at the bases. Maybe I can use them with the shoulder "out". And just got back from TSC with a big bag of $65 worth of other assorted bolts, nuts, and bushings that I MIGHT also need.
Did you know that it is not real easy to drill new 3/4" holes in 1/4" steel implement frames and struts?
Sheesh!
   / New to Quick Hitches - What do I need? #25
Sheesh!
Even with all the great inventions of the last 50 years, you still can't go into a hardware store and buy a box of 3/4 inch holes.
Bruce
   / New to Quick Hitches - What do I need? #26
Sheesh!
This is what I'm trying to avoid.
Does the Speeco (or other brand) have the same top hook issues or clearance issues as the imports?
Thanks
   / New to Quick Hitches - What do I need? #27
I believe the simple answer is yes. Unless all of your implements were designed to be used with a QH. Because my real problem is that the implement, in this case a locally made box blade, was definitely NOT ever intended to be used with a quick hitch. So the top link frame of the BB is so fat from front to back that the QH top hook does not stick far enough out from its mounting to engage the top pin of the implement. And the "N" dimension of any and all holes in the top link frame is random, certainly NOT the specified QH-compatible 14.78" - 14.88".
So if your implements are not designed to be QH compatible, and even if they are in some cases, you are forced to make some mods.
Pat's QH, that only attaches to the lift pins, avoids all of this, but then you do still have to manually connect your top link.
   / New to Quick Hitches - What do I need? #28
Some nice work by the local welding and fab shop.
As noted, I needed to extend the back of my top hook like others have done with my "Country Way" chinese QH. Turns out it is 1 -3/16" thick and shop only had 1 -1/8 or 1 - 1/4 stock. Said he could use the thicker stock, weld, and then mill it back down so it would all be the same thickness. But would cost me $20+ extra to set up the mill. I was already in for the stock and $65 for one hour minimum shop time. Paid a total of $120, but also got a 5' section of 1" square tube and had that stitch welded to a matching piece of 1 - 1/4 angle for another project.
I think I got a great deal. Agree?
   / New to Quick Hitches - What do I need? #29
The effect of moving the top hook rearward or forward is the attachment will no longer hang level. A change in the top link length will be required for correction.
   / New to Quick Hitches - What do I need? #30
Thanks
My QH is Speeco and it does have the extended top hook, places the hook out far enough that the side frames of implement top link do not hit the pins of the hook.
Sure this moves the top out but every implement I have requires different setting of top link anyway. That is one of 2 reasons I have hydraulic top link. Other reason (primary reason) for the hydraulic link is to grab the top link first then pull the implement that last 1 -2" into the hitch, then raise and lock it in from tractor seat.
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2005 Ford F650 Fire Truck (A49461)
2005 Ford F650...
2009 Mini Cooper Clubman Sedan (A50860)
2009 Mini Cooper...
2013 INTERNATIONAL 4300 26 FT BOX TRUCK (A51222)
2013 INTERNATIONAL...
2015 Ford Fusion S Sedan (A48082)
2015 Ford Fusion S...
2021 23ft Cypress Cay Seabreeze 232 Pontoon Boat with 23ft Single Axle Trailer (A48082)
2021 23ft Cypress...
