New to Quick Hitches - What do I need?
   / New to Quick Hitches - What do I need? #41
Kenny, you might just be right!
Still would have been good of the chinese at "Country Way" to have made the minimum a touch less than 15" to keep the top hook from being the main support.
   / New to Quick Hitches - What do I need? #42
Carbide Grit blades are available for hack saws and reciprocating saws. Also cutoff disks if you have something to drive them. A drillpress on "high" would work.
Thanks! For some reason I had not considered a cutoff wheel. I don't have a chop saw, but an angle grinder should do if I'm careful to not get too deep and bind it.
   / New to Quick Hitches - What do I need? #43
I didn't read all the posts so somebody might already mention it. What you need is hydraulic top link. It makes the quick hitch quick.
   / New to Quick Hitches - What do I need? #44
The product is fine but do not buy from Pats website because the return policy is a joke, no spacer bar, plus you will pay about $60 more than if you bought from Rural King, even Amazon is a lot less.
   / New to Quick Hitches - What do I need? #45
Got all the little mods finished up on the box blade today and tried it all out. Works great! First thing I learned: it's going to be necessary to unhook the box blade on some 4x4s or a pallet. Else it's too low to the ground to get under with the QH hooks. This time, I had to lift up the front of the whole tractor with the FEL bucket and skid back under it!
I have about a 1/4" to 1/2" gap between the bottom of the top pin and the top hook when the lift pins are securely bottomed in the lift hooks. That's about right, right?
   / New to Quick Hitches - What do I need? #46
Drilling 3/4 holes in steel is done easiest with a good quality hole saw in my experience.
   / New to Quick Hitches - What do I need? #47
You need to adjust the side turnbuckles to lower the 3 point. You should be able to lover the arms to the ground.
   / New to Quick Hitches - What do I need? #48
Kubota L4330 has only a right side lift arm adjustment. Left arm cannot be lowered any more than about 4-6" off the ground, and this has the tip of the QH hook at maybe 10-12" up.
   / New to Quick Hitches - What do I need? #49
Do you have two or three holes in the lower arms? What holes are the side links in? This changes lift geometry.
   / New to Quick Hitches - What do I need? #50
For about the third time now, just in this thread, you guys have educated and/or corrected me. It is true, as said in another thread recently, that you learn something new on TBN every day. And ONE of things I am learning is that my chemo is affecting my brain a lot more than I previously admitted.
Seems I DO have additional adjustments in BOTH my lift arms and links! Don't know how I never really noticed that before! It is adjusted the way it came from the dealer.
So I COULD leave it as-is and just unhook my box blade on some pallets. I have no problem doing this. OR, I could reset to either lower side link holes, OR closer-in lift arm holes, OR both.
If I change to different holes, I wonder which would work best and why?
p.s. I agree that a good hole saw is the way to go when making new LARGE holes in thick steel. Much less metal to actually "cut" and much less tendency to grab.
p.p.s CompactTractorFan, I sincerely apologize for shamelessly taking over your thread. I will now cease and desist.
Texas Built 25' Stand Alone Inline Feeder (A50515)
Texas Built 25'...
IH 1066 Tractor (A50514)
IH 1066 Tractor...
Super C Pull-Type 40ft Land Leveler (A52128)
Super C Pull-Type...
2016 VOLVO EC300EL EXCAVATOR (A51242)
2016 VOLVO EC300EL...
2013 Chevrolet Malibu Sedan (A50324)
2013 Chevrolet...
