New Tires
/ New Tires #11
Sorry to hear about the water pump. I hope it's not too serious. I'm jealous of those turfs. My Ags make for a bumpy ride...
/ New Tires #12
I had to change the water pump on a L2550. It would have been much easier if it wasn't in the field and I could have used my air ratchet. An impact wrench won't fit.
/ New Tires #13
Those look really nice on your machine. And it's a nice tractor to start with! What are the dimensions of those turfs? And how many gallons of rimguard did it take to 'fill' them. I've been thinking about using -20WWF, but I'm not sure me or the tires are up for that right now. Some added stability would be nice not to mention some ballast and added traction.
Its easy to fill tires. I used a 15 gallon sprayer for like roundup. I took the wand off and used some fittings to adapt it to garden hose and then used a hose type attachment valve to the tire tube. Just turn the pump on and keep dumping in the tank. And every 5 mins or so cut the sprayer off and bleed the air from the valve. I filled my tires that way. I am thinking in my 9.5 x 24 that i got somethink like 8-9 gallons in each? And at what 8 pounds a gallon or whatever i only got like just under 80 pounds per tire in ballast. But i promise you it feels like way more!!! best mod money i have spent for sure, i know with 25 gallons per tire that thing will hook up like no ones business!
haha its a tractor not a cadilac!
/ New Tires
I've been climbing hills like a school boy (climb the hill for no other reason than to just see if i can do it), and can do some routine moves that used to require 4WD in 2WD. Rears weigh somewhere just north of 300lbs I figure.
I'll be starting a new water pump thread soon. Need to take another look at it to see if I should/need to replace the pump before anything catastrophic. The wobble worries me more than the noise...to boot I know my radiator is on borrowed time so I need to weigh that too.
/ New Tires #15
Radiator is most likely repairable. Put the Fan through it if the Water pump comes apart and you will be replacing it!! While your replacing the Water Pump I would have a Radiator shop Check and Clean it...:2cents:
/ New Tires
Good point. I hope you're right about being repairable. The core is suffering from exposure to the battery/acids, hole is at about battery height. Unfortunately I am lacking "official" radiator repair places in my area.
/ New Tires #17
Then I would Flush it while you have somewhat of a Water Pump. Then New WP, Belts, Hoses, New Antifreeze and my bet your be good for Yrs.. If the WP has that much play in it I wouldn't use anymore until I corrected the problems. Not worth it. And I'm sorry but yes start another thread.
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
24in excavator tooth bucket (A61307)
24in excavator...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
BRAD CO. TRENCHER (A60736)
BRAD CO. TRENCHER...
