New Tires
/ New Tires #1
Todd8665
AuTrain, MI
Kubota L3430
New tire kit from Hyoe installed! 25 gallons of rim guard in the rears.
Definitely feel a difference in the ride, seems to get great traction. Does however act differently in 4wd. I'll admit that I am guilty of popping it into 4wd while in motion. Now...that's a pretty stiff shift with the new tires. Will be stopping before shifting into/out of 4wd.
Super happy with them so far.
/ New Tires #2
I filled my rivers with windshield washer fluid and couldnt believe the difference it made!
/ New Tires
I thought about doing that, but to effective I'd have to buy top shelf washer fluid which ruins the cost effectiveness/per weight ratio. Gets pretty cold here and the "cheap" washer fluid freezes in my truck all the time :thumbdown:. Reminds me I need to stock up on the "good" washer fluid for winter....
/ New Tires #4
Yea i bought the winter stuff thats good to like -10 or something and then i actually cut it with a gallon or two of water per tire. I did my math on the alchohol and amout of water i added and think i made it good down to like 10-15F. Thats fine here. even though we got below that not long enough to do more than slush the top probably.
/ New Tires #5
i cant remember what the WWF alchohol is now? Is it methonol? i dont feel like googeling it now. I remember whatever it was you could get it in some food grade bucket in bulk for some purpose???perserving food or something :eek: Or was that methyl glycol or whatever the RV antifreeze is? i do know i looked into both but the WWF fluid was cheapest. I bought from Advanceautoparts online and basically got 40% off useing online codes. and then picked it up.
/ New Tires
My neighbor runs rim guard in his tires, and he like me keeps his tractor in a heated garage. However he tells me that on very cold days, -20F or lower, you don't want to keep that thing out there(sitting) for to many hours. He let his sit for a few hours once and it started to gel and swell a bit. Said his tires frosted up like a couple beer mugs once he pulled it back into his garage.
/ New Tires #7
I would think that at -20 if it gets like that would leave a ...whollop...whollop whollop of a ride. But i personally would not be driving the tractor much in -20f unless i guess to remove snow if it was comeing down so fast as i had to stay on top of it.
/ New Tires
Believe you me I try and avoid it, but sometimes bad timing, unforeseen circumstances, and poor preparations make for a cold afternoon...on or off the tractor.
/ New Tires #9
Those look really nice on your machine. And it's a nice tractor to start with! What are the dimensions of those turfs? And how many gallons of rimguard did it take to 'fill' them. I've been thinking about using -20WWF, but I'm not sure me or the tires are up for that right now. Some added stability would be nice not to mention some ballast and added traction.
/ New Tires
Thanks, but looks can be a smidgen deceiving.
Rears are 13.6-16 and fronts are...nuts i cant remember exactly...8.75 ahh ill have to take a look at them. Each rear tire took 25 gallons @ 10.7-11lbs per gallon. Traction improvement thus far has been enormous.
Off to check the price of a water pump. Cleaned/flushed then added new antifreeze and now my water pump is sounding a bit gravelie, and you can see a bit of wobble in the fan belt:(
/ New Tires #11
Sorry to hear about the water pump. I hope it's not too serious. I'm jealous of those turfs. My Ags make for a bumpy ride...
/ New Tires #12
I had to change the water pump on a L2550. It would have been much easier if it wasn't in the field and I could have used my air ratchet. An impact wrench won't fit.
/ New Tires #13
Its easy to fill tires. I used a 15 gallon sprayer for like roundup. I took the wand off and used some fittings to adapt it to garden hose and then used a hose type attachment valve to the tire tube. Just turn the pump on and keep dumping in the tank. And every 5 mins or so cut the sprayer off and bleed the air from the valve. I filled my tires that way. I am thinking in my 9.5 x 24 that i got somethink like 8-9 gallons in each? And at what 8 pounds a gallon or whatever i only got like just under 80 pounds per tire in ballast. But i promise you it feels like way more!!! best mod money i have spent for sure, i know with 25 gallons per tire that thing will hook up like no ones business!
haha its a tractor not a cadilac!
/ New Tires
I've been climbing hills like a school boy (climb the hill for no other reason than to just see if i can do it), and can do some routine moves that used to require 4WD in 2WD. Rears weigh somewhere just north of 300lbs I figure.
I'll be starting a new water pump thread soon. Need to take another look at it to see if I should/need to replace the pump before anything catastrophic. The wobble worries me more than the noise...to boot I know my radiator is on borrowed time so I need to weigh that too.
/ New Tires #15
Radiator is most likely repairable. Put the Fan through it if the Water pump comes apart and you will be replacing it!! While your replacing the Water Pump I would have a Radiator shop Check and Clean it...:2cents:
/ New Tires
Good point. I hope you're right about being repairable. The core is suffering from exposure to the battery/acids, hole is at about battery height. Unfortunately I am lacking "official" radiator repair places in my area.
/ New Tires #17
Then I would Flush it while you have somewhat of a Water Pump. Then New WP, Belts, Hoses, New Antifreeze and my bet your be good for Yrs.. If the WP has that much play in it I wouldn't use anymore until I corrected the problems. Not worth it. And I'm sorry but yes start another thread.
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
WHITE 2-60 TRACTOR (A63291)
WHITE 2-60 TRACTOR...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A63688)
2021 Unverferth...
2005 Sterling Acterra Tender Truck (A63688)
2005 Sterling...
