New switch
/ New switch #1
pekabu
Platinum Member
NH
TC24D
Ok, I feel kinda stupid but I am having trouble with this little switch from Radioshack. It has three inputs, one ground, one load, and one power. It is a lighted switch. It currently works (the worklight), but the light in the switch does not. If I attach a wire from the ground plug to a bolt, it blows the fuse. I can't remember right now if the Power from the tractor goes to the load or power line. I assumed the "Power" would be from the tractor, and the "Load" would be the work light (not switch light).
Thanks
Dave /forums/images/graemlins/confused.gif
/ New switch #2
Pull out your trusty radio shack vom, and do some checks / tests... only 3 connections.
Also.. check to make sure you have the polarity correct, and that it is not a spdt switch with the ground for the illuminator light comming from something like the mounting band/ or case if a metal switch.. etc.
Soundguy
/ New switch #3
Just out of curiosity, is that switch WATER PROOF?
I have and am still considering adding an extra set of lights to at least one tractor and I can't find a good water proof switch. I want one that will stand up to a good soaking from rain. And yes, I do keep my tractors inside most of the time, but every once in a while one or more of them end up in the weather and I want a fully weather shield switch.
Anyone know of a good source?
The automotive stores seems to carry a lot of switches but they are made for inside a car not for exposure to weather on a tractor.
/ New switch
Hi Bob, no. Needed something asap, and grabbed it. Hope to find something better later.
/ New switch #5
One lead is got to go to 12V.
A second needs to go to the load.
However, you may have two options for the load a normally on lead and a normally off lead.
So get a ohmeter or digital multimeter and connect it to one lead and measure the other two with the switch on and off. If you try the combinations you will figure it out.
It helps if you have a meter with tone continuity/diode checker. It will beep when you have a low resistance connection between the two meter leads.
Sometimes the third lead is used to light the switch and also needs to be tied to 12V.
Fred
/ New switch #6
Try the CAT dealer
A friend of mine converts shibauras over to the dpdt
switches. They are the only ones I know that make a water proof one at 22.00 bucks ea. (ouch!!) /forums/images/graemlins/shocked.gif
Ernie
/ New switch #7
Any switch labeled "Marine' duty will fill your needs, if it is of the type you need = SPST, SPDT, DPDT,ect.
One school of thought says mount the switch upside-down for protection of rainwater getting into the switch.
Rain water being ( hopefully) without any conductive material within it, would not cause a short within the switch.
What does happen is it, the rainwater, carries the fine dirt, sediment and so forth along with it, into the switch.
Non - Marine toggle switches can be fitted with a rubber boot that screws onto the threads also. At an extra cost.
These boots are available thru, Carquest,Napa,Etc. One well known brand is Cole Hersey, as in the switch company.
Hope you find this to be of some help.
Lloyd
/ New switch #8
The center terminal is your fused power into the switch.
The Pilot lamp function of the switch can be wired 2 different ways, Normal vs series.
Since your fuse is blowing when you push the switch to the "on" posistion, swap the wires
located at the outside ends of the switch. Sounds like you have the Load terminal going to ground.
The pilot lamp terminal is the one normally switched to ground.
Disconnect both of the end wires, leaving only the center fused hot wire connected to the switch.
Does the fuse still blow? when you push the switch on? Yes means you have a bad switch, or at
least a switch that is being shorted to ground for some reason.
Connect one more wire, lets say the Load terminal, A short to ground between the switch and
worklight, as well as within the worklight, will cause the fuse to blow.
Some switches have a diagram type of label on them, some don't. If your's doesn't, look at it very
carefully for the letters, p= pilot, x= power, l= load.
As the earlier posters stated, using an Ohm meter will help you figure out which term is the Load
(out to the worklight) connection. Holding the red & black tester leads onto each other- without
touching the Metal tips, take a reading. This is usually 5-7 ohms. On a high quality switch you may
see an additional 1/2 ohm when taking a reading thru the switch. So/So quality switches are around
1-2 ohms in addition to your initial reading of 5 or so ohms.
The Pilot to center "power-in" term will give you a higher reading because you are measuring the
resistance of the Pilot Lamp.
NO...the color of the pilot light doesn't count! That was for you Soundguy!
Hope this helps, or at least explains the proceedure for you....
Lloyd
Everything Electrical works with "Smoke". Let the smoke out, presto- stops working.
/ New switch #9
Thats the secret to electricity..........NEVER let the "magic" smoke out of the box.......... /forums/images/graemlins/grin.gif
/ New switch #10
Ancor makes a water proof switch, see the link below. I use them for the safety strobe light system on my tractor. I use 5 of them and they seem to be the same type of switch that New Holland uses for the crusie control on the TC 24D.
Ancor Switch PDF file
  • 325852-circuit_breakers_pag65.pdf
/ New switch
Thanks for the help guys. I ordered some permanant switches today. I wen't with the Cole Hersee Rocker switch. A bit pricey $15 each, but they have the dependand and indenedant pilot lights on them. We will see if I can screw them up to. /forums/images/graemlins/frown.gif
/ New switch #12
Pekabu,
What switch was it that you ordered? My dealer installed 3 lights on my ROPS, but I am a little worried about the plain toggle switch they have mounted below the left side of the dash. I was thinking about something like you are describing or perhaps along the lines of the New Holland cruise control switches. Any suggestions??
Thanks,
Jerry
/ New switch
Hi Jerry, well I ended up going with the same switches the LAGeorge put on. SPST with on light. I haven't received them yet because they were out of stock. Here is a link to the switch. (hopefully the same as George's). Go 2 Marine
Also, check out this thread. The second attachment is a picture of George's tractor switches. It's a very nice shot.
"It was a safety thing........ Strobes" by LAGeorge
/ New switch #14
Thanks Pekabu,
Just ordered mine too. Hopefully I'll be able to cut the dash ok to make it fit.
Jerry
/ New switch #15
</font><font color="blue" class="small">( Just out of curiosity, is that switch WATER PROOF?
Anyone know of a good source? )</font>
Hi guys,
Sorry I am late chiming in on this, but I think that Del City carries the type switches that you are looking for. They list a "SURF 'N TURF" switch in their catalog. It comes in a couple of styles with both plain and illuminated in each style. They recommend these for 'marine panels, . . . farm equipment and recreation equipment'.
My wife manages a marine products manufacturer. They fabricate the dashes for a huge chunk of the sport boat industry, of course these dashes contain gauges and switches. I talked to one of their engineers and was advised that they used these switches for a few years until the boat manufacturers wanted different designs. They had no issues with water damage to the switches.
I bought 3 of these along with relays, a fuse block and some other 'stuff' from Del City. One switch was to replace the factory original and the others were for the new forward lights and rear work light on my TC30. With some scrap from her company and a bit of futzing I was able to install them in the lower panel where the single factory light switch was located, turned out pretty nice. (no pictures available)
Sorry to bore you with all this. The important thing is that the switches were $6.04 each. The only problem with this company is that you need a $25.00 minimum order, well for me that was easy!
Web site is delcity.net
Again, sorry for posting this so late.
Don
/ New switch #16
I remember Del City from many years ago. They are a great company to do business with and have only the best of quality. Thanks for the link.
2004 STRICK 53X102 T/A DRY VAN TRAILER (A59914)
2004 STRICK 53X102...
2020 CASE TV450B SKID STEER (A65053)
2020 CASE TV450B...
Worksaver 3 Point Post Hole Digger (A65640)
Worksaver 3 Point...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
Landhonor Mini Skid Steer Quick Attach Grapple Bucket (A66285)
Landhonor Mini...
2025 PJ CC162 T/A 16FT EQUIPMENT TRAILER (A59914)
2025 PJ CC162 T/A...
