New rake
/ New rake #1
Ryansweatt2004
West gardiner maine
2017 kubota L3901 HST
Well it took selling two smaller landpride rakes and saving a little before I could finally order my new landpride LR3784 offset landscape rake. Took over a month for the dealer to get it in on their landpride shipment so I wouldn't have to pay for freight but it was well worth it. Definitely a heavy duty rake and I shouldn't have to worry about bending this one.
/ New rake #3
I really like the wheels on my ETA rake as they make any surface grooming easy.
/ New rake #4
Your going to like it..LOT.:thumbsup:
/ New rake
I had an LR1584 before this so I wanted to keep with the 7ft width but the side shift abilities make it so I can stay out away from the low lying branches when doing brush clean up along the sides of our 1/2 mile road. The only thing I don't like about it is because of the hydraulic cylinder mounts, it can't be rotated 360 degrees like my only 15 series rake. I used to like turning my old rake around and using it to push brush into piles. Nothing I can't adapt to now though. I mainly need the rake for finish grading dirt and road surfaces more than anything else.
/ New rake #6
Can you remove the pin(bolt?) that attaches the hydraulic cylinder, or does it look like it just won't be able to turn around? I know the wheels might present a bit of a challenge. I've used one rotated 180 like you say to push brush, but haven't done that very much (it feels kind of weird as the tines spring all over the place).
/ New rake
It's just the mounting bracket that's in the way. The rake is setup to be upgraded with hydraulic swing and rotation if I ever get rear hydraulics installed on my tractor. The gauge wheels did have to be taken off to rotate 360 onnmy old rake as well.
