New PT attachments
/ New PT attachments #41
MR
Just started using my box blade on new project and so far it has done well.
PJ
/ New PT attachments #43
<font color="blue"> Where do you guys find the time </font>
I work in computers, so I am at a computer terminal about 6 hours a day. Also support several hundred users. Good job. At home, I sit in the living room, playing with the kids, helping with homework, watching the history or discovery channel and playing on the computer while the laundry is running. Everyone in my house is usually asleep by 9:00pm except me. Then I do stuff in the basement, where there is another computer. I hit the hay around midnight-1:00am most nights and get up at 6:00. Never turn the computer on in the mornings. Total, I probably spend less than an hour here each day. But that is accumulated in 2-3 minute sessions throughout the day. /forums/images/graemlins/laugh.gif
/ New PT attachments #44
PJ,
Are you taking some photos? I'd like to see how it works, and get your opinion of it.
/ New PT attachments #45
Will try and get what you want. Don't have a great need right now in that direction as I will be starting the new tractor barn next week. Also working on the underground sprinkler system and using the box blade in that project. So far the leveling is better than expected. have not used the cutters as yet.
PJ
/ New PT attachments #46
Don't worry about the photos, as your opinion is what I'm really after. /forums/images/graemlins/wink.gif
/ New PT attachments #47
Worked on leveling the drive in the new garage area. The ground had very hard ruts from driving over it all winter. Used the box blade with teeth up and worked slow going backwards cutting the ruts out. Worked great as long as you go slow and do not try and take to big a bite at once. A couple of times over the high points and I was able to pick up speed and do a final leveling. Also used the box blade to pull dirt out from a tight wall. This worked great as the sides held the dirt as I pulled it away from the wall and then switched to the bucket and picked up. Used the float position for most of the work but felt that I could do just as well in the manual mode.
PJ
PJ
1993 International 4900 Utility Flatbed Truck (A64194)
1993 International...
2016 FREIGHTLINER CASCADIA 125 DAYCAB ROAD TRACTOR (A65054)
2016 FREIGHTLINER...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2001 VIBROMAX W1106PD ROLLER (A66091)
2001 VIBROMAX...
2017 GENIE S-40 TELESCOPIC BOOM LIFT (A65053)
2017 GENIE S-40...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
