New owner
/ New owner #1
Lowridin67
Mitsubishi MT180D
So, I got my first tractor. I found a Mitsubishi MT180D for what I thought was a good deal. It is an 18.5 HP 3 cyl diesel, 4WD, manual trans. It came with a 4' box scraper and I "stole" a 60" Bush Hog for $150. The Bush Hog is a little heavy and I want to add some ballast to the front. What is a good source for ballast?
I've been looking for a used FEL, but not sure what will be compatible. I am an engineer and fabricator, so I'm not afraid to have to modify something. But I haven't had the chance to look at a compact with one to see how they attach.
I've been thinking about making an attachment to have a quick release for the 3 point and incorporate a ball to be able to move my boat, car trailer and chicken coup around. Before I do, does anyone know of one I can just purchase?
Thanks for your help.
/ New owner #3
Welcome to TBN and I hope you find your answers
/ New owner #4
Quick Google Search for a FEL on your tractor found this:
/ New owner #5
Welcome to TBN.
Over the years TBN'ers have come with good ideas...use SEARCH and kick back.
/ New owner #6
If you proceed with adding the fel you can skip the front weights. I had to add 200 lbs of suitcase weights to my first non fel equipped tractor to keep the front end down when using most rear implements.
Enjoy your tractor!
/ New owner #8
Had a Mitsubishi MT20D. Great tractor and would do anything for its size. Started out with a 4' brush hog , was perfect. Tried a 5'. Would handle everything and like yours was a bit heavy. Decided to stick with the 4'er . Didnt want to break the tractor. Maybe too much torque if it hit something. Make sure you run a PTO with a clutch on it. Too hard to get replacement parts for. Easy one to trade a 5' for a 4' one for.
/ New owner #9
2015 Ford F-150 Ext. Cab Pickup Truck (A61573)
2015 Ford F-150...
(INOP) JOHN DEERE 694 CORN HEAD (A63291)
(INOP) JOHN DEERE...
Fellabuncher Dangle head, PARTS ONLY (A62679)
Fellabuncher...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
11in. Tooth Excavator Bucket (A64194)
11in. Tooth...
2016 PETEBILT 579 69 SLEEPER (A62613)
2016 PETEBILT 579...
